跳转到主内容
加入维修社区 - 创建账户
Shark ION Robot R75 Drive Wheel Assembly Replacement
你所需要的
    1. Shark ION Robot R75 Drive Wheel Assembly Replacement, Battery: 步骤 1 中的图像 1,3 Shark ION Robot R75 Drive Wheel Assembly Replacement, Battery: 步骤 1 中的图像 2,3 Shark ION Robot R75 Drive Wheel Assembly Replacement, Battery: 步骤 1 中的图像 3,3
      • Make sure the robot is shut off by pressing the power button on top.
      • Flip the R75 over so that the underside is facing up.
      • Using a Phillips #1 screwdriver, remove the 4mm screw in the battery cover.
      • Remove the battery cover.
      添加评论
    2. Shark ION Robot R75 Drive Wheel Assembly Replacement: 步骤 2 中的图像 1,3 Shark ION Robot R75 Drive Wheel Assembly Replacement: 步骤 2 中的图像 2,3 Shark ION Robot R75 Drive Wheel Assembly Replacement: 步骤 2 中的图像 3,3
      • Be careful when removing the battery, as it will still be connected to a wire.
      • Slowly pull the white tabs outward to remove the battery.
      添加评论
    3. Shark ION Robot R75 Drive Wheel Assembly Replacement: 步骤 3 中的图像 1,2 Shark ION Robot R75 Drive Wheel Assembly Replacement: 步骤 3 中的图像 2,2
      在这个步骤中使用的工具:
      • Be careful when removing the connector, as the part can break if too much force is used.
      • Push down on the tab of the battery connector using a set of tweezers and pull the connector away from the robot to free the wire.
      • Remove the battery from the device.
      添加评论
    1. Shark ION Robot R75 Drive Wheel Assembly Replacement, Drive Wheel Assembly: 步骤 4 中的图像 1,1
      • Flip the R75 to its underside.
      • Make sure the R75 is shut off.
      • For extra security, disconnect the battery by following the prerequisite guide.
      添加评论
    2. Shark ION Robot R75 Drive Wheel Assembly Replacement: 步骤 5 中的图像 1,3 Shark ION Robot R75 Drive Wheel Assembly Replacement: 步骤 5 中的图像 2,3 Shark ION Robot R75 Drive Wheel Assembly Replacement: 步骤 5 中的图像 3,3
      • Using a Torx T15 screwdriver, remove the five screws from the drive wheel assembly.
      • Carefully lift the drive wheel assembly from the wheel well by gently pulling up on the wheel.
      • The assembly will still be connected to the motherboard via a cable, so be sure not to pull so hard that the cable rips.
      添加评论
    3. Shark ION Robot R75 Drive Wheel Assembly Replacement: 步骤 6 中的图像 1,3 Shark ION Robot R75 Drive Wheel Assembly Replacement: 步骤 6 中的图像 2,3 Shark ION Robot R75 Drive Wheel Assembly Replacement: 步骤 6 中的图像 3,3
      • Flip the wheel assembly over and disconnect the cable connector on its underside.
      • Remove the drive wheel assembly.
      • Repeat this process for the other side if necessary.
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
6指南评论
Where I can buy the Shark ION Robot R75 Drive Wheel Assembly Replacement?
Thanks for your help!
xoxolo - 回复 分享
Do you know what the drive wheel motor cable is (see Step 6)? It's a 6 pin to 5 pin and the grooves are on the thin side and pitch of ~1.4mm. Possible a JST ZH?
Seth T - 回复 分享
I appreciate the step-by-step instructions with pictures... this was very helpful. However, my rv750 doesn't have the screws by the wheel assembly.
I've removed the screws, but it appears that I will need to separate the bottom from the top to access the wheel assemblies. Do you have a step=by step for the rv750 that has the wheel assembly enclosed?
RandiB - 回复 分享
The right wheel ass has a small gear striped inside, can you buy the small gears to repair the wheel drive?
Jerry Rotenberry - 回复 分享
I'm going to try these from Walmart
https://www.walmart.com/ip/5Pcs-set-Inte...
Miles Morgan - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 49
总计 10,872
