跳转到主内容
加入维修社区 - 创建账户
Shark ION RV754 Battery Replacement
你所需要的
    1. Shark ION RV754 Battery Replacement, Battery: 步骤 1 中的图像 1,1
      • Place the unit on its back with the wheels facing up.
      • Use a Phillips #1 screwdriver to remove the single screw securing the battery compartment door.
      • Use your finger to lift off the battery door using the small indent next to it.
      询问修复机器人
      添加评论
    2. Shark ION RV754 Battery Replacement: 步骤 2 中的图像 1,3 Shark ION RV754 Battery Replacement: 步骤 2 中的图像 2,3 Shark ION RV754 Battery Replacement: 步骤 2 中的图像 3,3
      • Lift the battery out just above the compartment to access the battery connector.
      • Squeeze the tab against the connector and pull it straight up to disconnect it.
      • Remove the battery completely.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
取消:我没有完成这个指南。
Ethan
于01/30/25注册
418 声望
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 41
总计 297
