跳转到主内容
加入维修社区 - 创建账户
Sew a Straight Stitch
你所需要的
  1. Sew a Straight Stitch, Sew a Straight Stitch: 步骤 1 中的图像 1,2 Sew a Straight Stitch, Sew a Straight Stitch: 步骤 1 中的图像 2,2
    • Thread your needle and tie a knot in the end of the thread.
    • We're using contrasting thread for visibility, but when you do your repair you will want to use matching thread.
    • Drive the needle through the back of the bottom material.
    • Pull the thread taut.
    询问修复机器人
    添加评论
  2. Sew a Straight Stitch: 步骤 2 中的图像 1,2 Sew a Straight Stitch: 步骤 2 中的图像 2,2
    • Drive the needle through the back side of the top material.
    • In this case we're sewing a buckle, but you can use this stitch to sew just about anything together.
    • Align the two materials in their final position.
    询问修复机器人
    添加评论
  3. Sew a Straight Stitch: 步骤 3 中的图像 1,2 Sew a Straight Stitch: 步骤 3 中的图像 2,2
    • Drive the needle down through both layers of material, coming out on the back side of the bottom material. Push the needle out of the material.
    • The closer you drive the needle in to where the thread came up, the smaller the stitch length. Having a smaller stitch length requires more stitches, but creates a stronger seam.
    询问修复机器人
    添加评论
  4. Sew a Straight Stitch: 步骤 4 中的图像 1,2 Sew a Straight Stitch: 步骤 4 中的图像 2,2
    • Ensure the two layers are correctly aligned.
    • Drive the needle through both layers of fabric from the back side of the bottom material, coming up on the top side of the top material.
    询问修复机器人
    添加评论
  5. Sew a Straight Stitch: 步骤 5 中的图像 1,3 Sew a Straight Stitch: 步骤 5 中的图像 2,3 Sew a Straight Stitch: 步骤 5 中的图像 3,3
    • Continue sewing through both layers, going down from the top and up from the bottom, as described in steps 3 and 4 of this guide.
    • When you come to the end of your material, draw the needle in between the two layers of material, under the thread of the closest stitch.
    • Slowly start to pull the thread taut. As you pull a loop will form.
    • Draw the needle through the loop and pull the thread taut.
    • Repeat the process of drawing the needle between the layers, creating a loop, and drawing the needle through the loop as described in this step.
    询问修复机器人
    添加评论
  6. Sew a Straight Stitch: 步骤 6 中的图像 1,1
    • Cut any remaining thread and admire your work.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
5等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
90,963 声望
创作了142篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 96
总计 5,230
