跳转到主内容
加入维修社区 - 创建账户
Seville Classics MSC10166 Disassembly
你所需要的
  1. Seville Classics MSC10166 Disassembly, PCB (Printed Circuit Board): 步骤 1 中的图像 1,1
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
    添加评论
  2. Seville Classics MSC10166 Disassembly: 步骤 2 中的图像 1,1
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
    询问修复机器人
    添加评论
  3. Seville Classics MSC10166 Disassembly: 步骤 3 中的图像 1,1
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
    询问修复机器人
    添加评论
  4. Seville Classics MSC10166 Disassembly: 步骤 4 中的图像 1,1
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
    询问修复机器人
    添加评论
  5. Seville Classics MSC10166 Disassembly: 步骤 5 中的图像 1,2 Seville Classics MSC10166 Disassembly: 步骤 5 中的图像 2,2
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
    询问修复机器人
    添加评论
  6. Seville Classics MSC10166 Disassembly, Rotating Blade and Transformer: 步骤 6 中的图像 1,2 Seville Classics MSC10166 Disassembly, Rotating Blade and Transformer: 步骤 6 中的图像 2,2
    • In order to remove the fan blade, use pliers to remove the holding nut.
    • After the holding nut is loose, use the pliers to pull up to remove the nut.
    询问修复机器人
    添加评论
  7. Seville Classics MSC10166 Disassembly: 步骤 7 中的图像 1,1
    • Remove the two bronze Phillips 29-mm bolts that hold the fan blade to the transformer.
    • Use a pair of pliers to hold the nut at the bottom of the transformer, as you unscrew from left-to-right at the top of the transformer. After, pull up and remove both the screw and nut.
    询问修复机器人
    添加评论
  8. Seville Classics MSC10166 Disassembly: 步骤 8 中的图像 1,2 Seville Classics MSC10166 Disassembly: 步骤 8 中的图像 2,2
    • Next, remove the two silver Phillips (8-mm head) 40-mm screws from the transformer.
    • Remove screws by pulling them away from the base.
    • The transformer should be free after this step.
    询问修复机器人
    添加评论
  9. Seville Classics MSC10166 Disassembly, Seville Classics MSC10166: 步骤 9 中的图像 1,2 Seville Classics MSC10166 Disassembly, Seville Classics MSC10166: 步骤 9 中的图像 2,2
    • Clean the track, removing any obstructions.
    • Lubricate the track with grease.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Queena Phung
于09/26/12注册
114 声望
创作了3篇指南
团队
Cal Poly, Team 15-46, Forte Fall 2012 Cal Poly, Team 15-46, Forte Fall 2012 的会员
CPSU-FORTE-F12S15G46
5 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 35
过去 30 天: 157
总计 12,665
