简介
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
你所需要的
Remove the All-In-One Cable from the cable guides along the left side of the head strap.
Peel off both front side foam pads to uncover the speaker wires.
Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
Four 3.9 mm screws (two on each side)
Two 4.1 mm screws (one on each side)
Use your fingers to gently peel the face rest cushion off of the headset.
Partially separate the facerest and the sensor array to access the daughterboard.
在这个步骤中使用的工具:Tweezers$4.99
Use a pair of tweezers to remove the Kapton tape covering the ZIF connector on the daughterboard.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
