简介
Use this guide to replace or remove the faceplate trim on your Scuf Reflex controller.
你所需要的
At the bottom tip of the right grip, insert the flat end of a spudger or a clean fingernail between the faceplate trim and the back cover.
Pry up to release the faceplate trim’s bottom right clip.
At the bottom tip of the left grip, insert the flat end of a spudger or a clean fingernail between the faceplate trim and the back cover.
Pry up to release the faceplate trim’s bottom left clip.
Insert the flat end of a spudger between the faceplate trim and the back cover, next to the headphone jack.
Pry up to release the plastic clips securing the center of the faceplate trim.
Lift the bottom edge of the faceplate trim and thread it up and over the thumbsticks.
Pull the top corners of the faceplate trim out from underneath the faceplate and remove the faceplate trim.
To reassemble your device, follow the instructions in reverse order.
