跳转到主内容
加入维修社区 - 创建账户
Sanyo VPC-T850 LCD Display Replacement
你所需要的
    1. Sanyo VPC-T850 LCD Display Replacement, Battery: 步骤 1 中的图像 1,1
      • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
      添加评论
    2. Sanyo VPC-T850 LCD Display Replacement: 步骤 2 中的图像 1,1
      • Locate the hatch found on the bottom of the camera.
      • Open the hatch by gripping the small notch and sliding it outwards.
      询问修复机器人
      添加评论
    3. Sanyo VPC-T850 LCD Display Replacement: 步骤 3 中的图像 1,1
      • Push the small, plastic arm out of the way to free the battery.
      • The battery is spring loaded and will pop out slightly when the arm is moved.
      询问修复机器人
      添加评论
    4. Sanyo VPC-T850 LCD Display Replacement: 步骤 4 中的图像 1,1
      • Pull the battery out of the camera and close the hatch.
      • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
      询问修复机器人
      添加评论
    1. Sanyo VPC-T850 LCD Display Replacement, Outer Casing: 步骤 5 中的图像 1,3 Sanyo VPC-T850 LCD Display Replacement, Outer Casing: 步骤 5 中的图像 2,3 Sanyo VPC-T850 LCD Display Replacement, Outer Casing: 步骤 5 中的图像 3,3
      • Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
      • Be sure to keep track of the side each screw comes from, as they come in different lengths.
      询问修复机器人
      添加评论
    2. Sanyo VPC-T850 LCD Display Replacement: 步骤 6 中的图像 1,2 Sanyo VPC-T850 LCD Display Replacement: 步骤 6 中的图像 2,2
      • Orient the camera so the display is facing up.
      • Gently pull off the rear panel surrounding the display.
      • There are still three green wires connecting the panel to the rest of the camera.
      • Use your prying tool if you have difficulties removing the panel by hand.
      询问修复机器人
      添加评论
    3. Sanyo VPC-T850 LCD Display Replacement: 步骤 7 中的图像 1,1
      • Remove the eight black screws connecting the keypad circuit board to the rear panel.
      询问修复机器人
      添加评论
    4. Sanyo VPC-T850 LCD Display Replacement: 步骤 8 中的图像 1,2 Sanyo VPC-T850 LCD Display Replacement: 步骤 8 中的图像 2,2
      • With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
      询问修复机器人
      添加评论
    5. Sanyo VPC-T850 LCD Display Replacement: 步骤 9 中的图像 1,1
      • Flip the camera over so the lens is facing up.
      • Gently lift up the front panel to remove it from the rest of the camera.
      • Use your plastic opening tool if you have difficulties removing the panel by hand.
      询问修复机器人
      添加评论
    1. Sanyo VPC-T850 LCD Display Replacement, LCD Display: 步骤 10 中的图像 1,1
      • Flip the device over to where the display is located.
      • Using your plastic opening tool, lift the display out of its metal housing.
      询问修复机器人
      添加评论
    2. Sanyo VPC-T850 LCD Display Replacement: 步骤 11 中的图像 1,1
      • Locate the orange ribbon connecting the display to the camera.
      • Using your plastic opening tool, gently lift the black bar holding the orange ribbon to the camera.
      询问修复机器人
      添加评论
    3. Sanyo VPC-T850 LCD Display Replacement: 步骤 12 中的图像 1,1
      • With two fingers held firmly on the display, gently pull the orange ribbon out of the camera.
      • Pull slowly to avoid severing the orange ribbon from the display.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Devin Farnsworth
于10/29/15注册
101 声望
撰写一个指南
团队
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 的会员
UMASSD-GULBRANDSEN-F15S5G5
3 名成员
创作了30篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 45
总计 845
