跳转到主内容
加入维修社区 - 创建账户
Sanyo VPC S1275 Function Set Replacement
你所需要的
    1. Sanyo VPC S1275 Function Set Replacement, Battery: 步骤 1 中的图像 1,1
      • Place your thumb on the right side of the camera over the battery door.
      • Slide the battery door to the right until the door lifts up.
      添加评论
    2. Sanyo VPC S1275 Function Set Replacement: 步骤 2 中的图像 1,1
      • Remove and recycle old batteries.
      询问修复机器人
      添加评论
    1. Sanyo VPC S1275 Function Set Replacement, Case: 步骤 3 中的图像 1,3 Sanyo VPC S1275 Function Set Replacement, Case: 步骤 3 中的图像 2,3 Sanyo VPC S1275 Function Set Replacement, Case: 步骤 3 中的图像 3,3
      • Remove the following six screws using the Phillips #00 screwdriver:
      • Two screws on the left side of the camera.
      • Two screws on the right side of the camera.
      • Two screws on the bottom of the camera.
      询问修复机器人
      添加评论
    2. Sanyo VPC S1275 Function Set Replacement: 步骤 4 中的图像 1,2 Sanyo VPC S1275 Function Set Replacement: 步骤 4 中的图像 2,2
      • Open the battery slot on the bottom of the camera by sliding the door to the right.
      • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    3. Sanyo VPC S1275 Function Set Replacement: 步骤 5 中的图像 1,3 Sanyo VPC S1275 Function Set Replacement: 步骤 5 中的图像 2,3 Sanyo VPC S1275 Function Set Replacement: 步骤 5 中的图像 3,3
      • Insert a spudger in the seam at the bottom of the camera.
      • Gently separate the rear case from the front of the camera.
      询问修复机器人
      添加评论
    4. Sanyo VPC S1275 Function Set Replacement: 步骤 6 中的图像 1,1
      • This step is only needed for the case and logic board replacement
      • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
      添加评论
    5. Sanyo VPC S1275 Function Set Replacement: 步骤 7 中的图像 1,1
      • This step is only needed for the case replacement.
      • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
      • Slide the battery door off of the hinge.
      添加评论
    1. Sanyo VPC S1275 Function Set Replacement, Function Set: 步骤 8 中的图像 1,2 Sanyo VPC S1275 Function Set Replacement, Function Set: 步骤 8 中的图像 2,2
      • Remove the function set strip by lifting it from the inside of the rear case.
      • The function strip is now free from the camera.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 24-24, Regan Spring 2010 Cal Poly, Team 24-24, Regan Spring 2010 的会员
CPSU-REGAN-S10S24G24
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 38
总计 3,220
