跳转到主内容
加入维修社区 - 创建账户
Samsung YP-P3 Touch Screen Replacement
你所需要的
  1. Samsung YP-P3 Touch Screen Replacement, Case Backplate: 步骤 1 中的图像 1,1
    • Pry up the small black piece of plastic located between the volume [-] button and the HOLD/ON button.
    询问修复机器人
    添加评论
  2. Samsung YP-P3 Touch Screen Replacement: 步骤 2 中的图像 1,1
    • Underneath the piece of plastic you just removed, there is a small screw (Phillips #000, 2.0 mm long). Use a Phillips #000 screwdriver to remove it.
    询问修复机器人
    添加评论
  3. Samsung YP-P3 Touch Screen Replacement: 步骤 3 中的图像 1,2 Samsung YP-P3 Touch Screen Replacement: 步骤 3 中的图像 2,2
    • Push on the backplate with both thumbs, sliding it towards the top of the device.
    • Once it begins to move, lift up slightly. You can then slide the backplate all the way off.
    询问修复机器人
    添加评论
  4. Samsung YP-P3 Touch Screen Replacement, Printed Circuit Board: 步骤 4 中的图像 1,3 Samsung YP-P3 Touch Screen Replacement, Printed Circuit Board: 步骤 4 中的图像 2,3 Samsung YP-P3 Touch Screen Replacement, Printed Circuit Board: 步骤 4 中的图像 3,3
    • Before removing the circuit board, we must remove the ribbon-like wires attached to two sides of the circuit board.
    • There are two screws (Phillips #000, 2.0 mm long) holding in the circuit board. Use a Phillips #000 screwdriver to take out those screws.
    询问修复机器人
    添加评论
  5. Samsung YP-P3 Touch Screen Replacement: 步骤 5 中的图像 1,2 Samsung YP-P3 Touch Screen Replacement: 步骤 5 中的图像 2,2
    • The battery is also attached to the circuit board by a cable. The cable is difficult to disconnect with both components in place. It's best to lift the circuit board out partially to give yourself more room to disconnect the connector.
    • The wire that is connected to the circuit board is connected by a plastic piece with two metal prongs.
    • Use the pointy end of the spudger to place in between the computer board and the plastic piece and gently pry the prongs away from the circuit board.
    询问修复机器人
    添加评论
  6. Samsung YP-P3 Touch Screen Replacement: 步骤 6 中的图像 1,1
    • Disconnect the battery connector, and then lift the circuit board up.
    询问修复机器人
    添加评论
  7. Samsung YP-P3 Touch Screen Replacement: 步骤 7 中的图像 1,1
    • Finally, disconnect the ribbon cable on the bottom of the circuit board. You can then lift the circuit board all the way out.
    询问修复机器人
    添加评论
  8. Samsung YP-P3 Touch Screen Replacement, Battery: 步骤 8 中的图像 1,1
    • Use the spudger to carefully pry up the battery. The battery is attached with a few spots of glue, so it may not move at first.
    询问修复机器人
    添加评论
  9. Samsung YP-P3 Touch Screen Replacement, Touch Screen: 步骤 9 中的图像 1,3 Samsung YP-P3 Touch Screen Replacement, Touch Screen: 步骤 9 中的图像 2,3 Samsung YP-P3 Touch Screen Replacement, Touch Screen: 步骤 9 中的图像 3,3
    • Remove the six screws (Phillips #000, 2.3 mm long) holding the screen frame to the front of the case. As the picture shows, one of them is hidden under the black speaker/rumble assembly.
    询问修复机器人
    添加评论
  10. Samsung YP-P3 Touch Screen Replacement: 步骤 10 中的图像 1,2 Samsung YP-P3 Touch Screen Replacement: 步骤 10 中的图像 2,2
    • To access the screw under the black speaker rumble/assembly, you will need to pry the assembly up slightly using the spudger.
    • The assembly is glued to the back of the screen, so the assembly may not move at first. Be patient and careful. Do not pry too hard, or you may break the assembly.
    询问修复机器人
    添加评论
  11. Samsung YP-P3 Touch Screen Replacement: 步骤 11 中的图像 1,1
    • Lift the screen out from the case.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Michigan Tech, Team 5-3, Lauer Spring 2014 Michigan Tech, Team 5-3, Lauer Spring 2014 的会员
MTU-LAUER-S14S5G3
4 名成员
创作了6篇指南
2指南评论
Hello, excellent instructions , great pictures only want to know if is possible to find the part ?? I mean Samsung doesnt sell the touch screen part in that case where to find it ?? because without the part the instructions are not worthy,,, sorry and thanks.
jo ca - 回复 分享
Very helpful guide. Do you have a manufacturer and part number for the touch screen?
Mark Garvin - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 76
总计 8,637
