跳转到主内容
Samsung Watch Active Sensor Array Replacement
你所需要的
  1. Samsung Watch Active Sensor Array Replacement, Turn off the watch: 步骤 1 中的图像 1,2 Samsung Watch Active Sensor Array Replacement, Turn off the watch: 步骤 1 中的图像 2,2
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Samsung Watch Active Sensor Array Replacement, Remove the rear screws: 步骤 2 中的图像 1,1
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: 步骤 3 中的图像 1,3 Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: 步骤 3 中的图像 2,3 Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: 步骤 3 中的图像 3,3
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: 步骤 4 中的图像 1,2 Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: 步骤 4 中的图像 2,2
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Samsung Watch Active Sensor Array Replacement, Remove the back cover: 步骤 5 中的图像 1,1
    • Remove the back cover.
  6. Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: 步骤 6 中的图像 1,3 Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: 步骤 6 中的图像 2,3 Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: 步骤 6 中的图像 3,3
    • Use an opening pick and slide it underneath the sensor array which is slightly glued in place.
    • Carefully twist the opening pick to separate the sensor array from the back cover.
  7. Samsung Watch Active Sensor Array Replacement, Remove the sensor array: 步骤 7 中的图像 1,2 Samsung Watch Active Sensor Array Replacement, Remove the sensor array: 步骤 7 中的图像 2,2
    • Remove the sensor array from the back cover.
结论
另外一个人完成了本指南。
Tobias Isakeit
于03/31/14注册
129,377 声望
创作了189篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,145篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 4,594
