跳转到主内容
加入维修社区 - 创建账户
Samsung WB1100F LCD Screen Replacement
你所需要的
    1. Samsung WB1100F LCD Screen Replacement, LCD Screen Cover: 步骤 1 中的图像 1,2 Samsung WB1100F LCD Screen Replacement, LCD Screen Cover: 步骤 1 中的图像 2,2
      • Remove six 1.2 mm Phillips #00 screws connected to the tripod dock and adjacent screws.
      • Remove six 1.2 mm Phillips #00 screws from the side of the camera.
      询问修复机器人
      添加评论
    2. Samsung WB1100F LCD Screen Replacement: 步骤 2 中的图像 1,2 Samsung WB1100F LCD Screen Replacement: 步骤 2 中的图像 2,2
      • Use a plastic opening tool or spudger if available.
      • Using the flat end of a spudger, loosen the connection between the back panel and the device. Remove the back panel using your hands.
      询问修复机器人
      添加评论
    1. Samsung WB1100F LCD Screen Replacement, LCD Screen: 步骤 3 中的图像 1,2 Samsung WB1100F LCD Screen Replacement, LCD Screen: 步骤 3 中的图像 2,2
      • Remove four 1.2 mm Phillips #1 screws connected to the LCD screen.
      询问修复机器人
      添加评论
    2. Samsung WB1100F LCD Screen Replacement: 步骤 4 中的图像 1,3 Samsung WB1100F LCD Screen Replacement: 步骤 4 中的图像 2,3 Samsung WB1100F LCD Screen Replacement: 步骤 4 中的图像 3,3
      在这个步骤中使用的工具:
      • Flip the LCD screen over to reveal the display cable.
      • Use the tip of a spudger or your fingernail to flip up the small retaining flap on the display cable ZIF connector.
      • Be sure you are prying up on the hinged retaining flap, not the connector itself.
      • Using a pair of tweezers, remove the ribbon cable from its socket on the motherboard.
      • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the retaining flap. If the cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Jesse Lindsey
于05/13/16注册
581 声望
创作了5篇指南
团队
Metro State, Team 1-1, Carpenter SU 2016 Metro State, Team 1-1, Carpenter SU 2016 的会员
MSU-CARPENTER-SU16S1G1
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 26
总计 806
