跳转到主内容
加入维修社区 - 创建账户
Samsung UBD-KM85C Disc Drive Replacement
你所需要的
    1. Samsung UBD-KM85C Disc Drive Replacement, Outer Shell: 步骤 1 中的图像 1,1
      • On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
      询问修复机器人
      添加评论
    2. Samsung UBD-KM85C Disc Drive Replacement: 步骤 2 中的图像 1,2 Samsung UBD-KM85C Disc Drive Replacement: 步骤 2 中的图像 2,2
      • From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
      询问修复机器人
      添加评论
    3. Samsung UBD-KM85C Disc Drive Replacement: 步骤 3 中的图像 1,3 Samsung UBD-KM85C Disc Drive Replacement: 步骤 3 中的图像 2,3 Samsung UBD-KM85C Disc Drive Replacement: 步骤 3 中的图像 3,3
      • There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
      询问修复机器人
      添加评论
    4. Samsung UBD-KM85C Disc Drive Replacement: 步骤 4 中的图像 1,1
      • Remove the cover from the device.
      询问修复机器人
      添加评论
    1. Samsung UBD-KM85C Disc Drive Replacement, Disc Drive: 步骤 5 中的图像 1,1
      • The disk drive is the large metallic rectangular unit that occupies a third of the space inside the unit.
      询问修复机器人
      添加评论
    2. Samsung UBD-KM85C Disc Drive Replacement: 步骤 6 中的图像 1,2 Samsung UBD-KM85C Disc Drive Replacement: 步骤 6 中的图像 2,2
      • The disk drive has four 6.5mm screws located near each of its corners that hold it onto the frame. Use a #1 Phillips head screwdriver to remove these screws.
      询问修复机器人
      添加评论
    3. Samsung UBD-KM85C Disc Drive Replacement: 步骤 7 中的图像 1,3 Samsung UBD-KM85C Disc Drive Replacement: 步骤 7 中的图像 2,3 Samsung UBD-KM85C Disc Drive Replacement: 步骤 7 中的图像 3,3
      • The disk drive has two connections to the motherboard that can be disconnected by pulling on the blue plastic tabs.
      询问修复机器人
      添加评论
    4. Samsung UBD-KM85C Disc Drive Replacement: 步骤 8 中的图像 1,1
      • Once the connections are unplugged and the screws are removed, the disk drive can be lifted out. The previous steps can be done in the reverse order to replace the part.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
James Edwards
于02/01/18注册
627 声望
创作了5篇指南
团队
Baylor, Team S2-G1, Johnson Spring 2018 Baylor, Team S2-G1, Johnson Spring 2018 的会员
BU-JOHNSON-S18S2G1
3 名成员
创作了12篇指南
1指南评论
How do I eject a disk that's stuck in the drive?
Martin Y - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 32
总计 724
