跳转到主内容
加入维修社区 - 创建账户
Samsung TL220 Battery Spring Replacement
你所需要的
    1. Samsung TL220 Battery Spring Replacement, Battery Spring Replacement: 步骤 1 中的图像 1,2 Samsung TL220 Battery Spring Replacement, Battery Spring Replacement: 步骤 1 中的图像 2,2
      • Begin by unscrewing all seven 4 mm phillip's screws located on the outside of the camera.
      • Using the plastic opening tool carefully pry open the camera, lifting the back casing off.
      询问修复机器人
      添加评论
    2. Samsung TL220 Battery Spring Replacement: 步骤 2 中的图像 1,2 Samsung TL220 Battery Spring Replacement: 步骤 2 中的图像 2,2
      • Now that you have the back casing off, gently move the LCD screen from the camera to the right and lay it facing down on the table.
      • Next unscrew the three 4 mm Philips screws on the back panel with the same screw driver.
      询问修复机器人
      添加评论
    3. Samsung TL220 Battery Spring Replacement: 步骤 3 中的图像 1,2 Samsung TL220 Battery Spring Replacement: 步骤 3 中的图像 2,2
      在这个步骤中使用的工具:
      • Unclip the four connectors with the plastic opening tool which holds down the orange film strips.
      • Gently with the tweezers remove the four orange film strips from the connectors.
      询问修复机器人
      添加评论
    4. Samsung TL220 Battery Spring Replacement: 步骤 4 中的图像 1,2 Samsung TL220 Battery Spring Replacement: 步骤 4 中的图像 2,2
      • Once the orange film strips have been released from the connectors, unscrew the Phillips 4 mm silver screw which holds down the top of the camera's frame.
      • With your fingers gently push up the camera's top frame. Once the camera's top frame is off you can than gently remove the camera's front casing off, as well.
      询问修复机器人
      添加评论
    5. Samsung TL220 Battery Spring Replacement: 步骤 5 中的图像 1,2 Samsung TL220 Battery Spring Replacement: 步骤 5 中的图像 2,2
      • Flip the entire camera over so that the lenses are facing upward with the LCD screen showing to the side.
      • Now remove the silver case, seen demonstrated in the picture.
      询问修复机器人
      添加评论
    6. Samsung TL220 Battery Spring Replacement: 步骤 6 中的图像 1,1
      • After all the parts are disassembled, you will reach the spring part of the camera.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
chelsa
于03/03/15注册
358 声望
创作了3篇指南
团队
3 Tech Girls 3 Tech Girls 的会员
Community
2 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 24
总计 1,011
