跳转到主内容
加入维修社区 - 创建账户
Samsung SPEX SCH-R210 antenna Replacement
你所需要的
    1. Samsung SPEX SCH-R210 antenna Replacement, Back Cover: 步骤 1 中的图像 1,3 Samsung SPEX SCH-R210 antenna Replacement, Back Cover: 步骤 1 中的图像 2,3 Samsung SPEX SCH-R210 antenna Replacement, Back Cover: 步骤 1 中的图像 3,3
      • Lay the phone on its front side so the back is visible.
      • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
      • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
      • Slide the cover down from the phone to remove it. Set the cover aside.
      询问修复机器人
      添加评论
    1. Samsung SPEX SCH-R210 antenna Replacement, Battery: 步骤 2 中的图像 1,1
      • Locate the access notch at the end of the battery compartment.
      询问修复机器人
      添加评论
    2. Samsung SPEX SCH-R210 antenna Replacement: 步骤 3 中的图像 1,1
      • Place your thumb on the edge of the battery near the access notch.
      • Lift the battery to remove it from the phone. Set the battery aside.
      询问修复机器人
      添加评论
    1. Samsung SPEX SCH-R210 antenna Replacement, Antenna: 步骤 4 中的图像 1,2 Samsung SPEX SCH-R210 antenna Replacement, Antenna: 步骤 4 中的图像 2,2
      • After removing the battery, unscrew the 4 3/16" screws on the black plastic cover with the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    2. Samsung SPEX SCH-R210 antenna Replacement: 步骤 5 中的图像 1,2 Samsung SPEX SCH-R210 antenna Replacement: 步骤 5 中的图像 2,2
      • Remove the headphone cover from the left side and the volume cover from the right side of the phone.
      询问修复机器人
      添加评论
    3. Samsung SPEX SCH-R210 antenna Replacement: 步骤 6 中的图像 1,1
      • Remove the black plastic cover from the back of the phone. This may take a little effort to remove.
      询问修复机器人
      添加评论
    4. Samsung SPEX SCH-R210 antenna Replacement: 步骤 7 中的图像 1,1
      在这个步骤中使用的工具:
      • The antenna is located on the opposite side of the black plastic cover. Use the tweezers to remove the antenna.
      询问修复机器人
      添加评论
    5. Samsung SPEX SCH-R210 antenna Replacement: 步骤 8 中的图像 1,1
      • The gray rubber antenna cover will need to come out as well. Use the tweezers to remove the gray cover.
      询问修复机器人
      添加评论
    6. Samsung SPEX SCH-R210 antenna Replacement: 步骤 9 中的图像 1,1
      • Replace with a new antenna.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Susan
于07/11/13注册
331 声望
创作了3篇指南
团队
WRI115, Team 1-4, Ruszkiewicz Spring 2013 WRI115, Team 1-4, Ruszkiewicz Spring 2013 的会员
WRI115-RUSZKIEWICZ-S13S1G4
3 名成员
创作了45篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 17
总计 557
