跳转到主内容
加入维修社区 - 创建账户
Samsung SGH-X495 Screen Replacement
你所需要的
    1. Samsung SGH-X495 Screen Replacement, Backplate: 步骤 1 中的图像 1,1
      • Remove the 4 (4.7mm) philips head screws.
      询问修复机器人
      添加评论
    2. Samsung SGH-X495 Screen Replacement: 步骤 2 中的图像 1,1
      • Unplug the rubber charger outlet cover.
      询问修复机器人
      添加评论
    3. Samsung SGH-X495 Screen Replacement: 步骤 3 中的图像 1,1
      • Unplug the rubber headset jack cover.
      询问修复机器人
      添加评论
    4. Samsung SGH-X495 Screen Replacement: 步骤 4 中的图像 1,2 Samsung SGH-X495 Screen Replacement: 步骤 4 中的图像 2,2
      • Begin by inserting the pry tool near the charger jack.
      • There are 4 tabs to release.
      • Start at the bottom and slide the tool up, lifting the silver front of the phone away from the white backing.
      • Loosen the 2 side tabs before moving on to the top two.
      • See the second photo to see location of the tabs.
      • Be careful of the ribbon wires shown in second photo.
      询问修复机器人
      添加评论
    5. Samsung SGH-X495 Screen Replacement: 步骤 5 中的图像 1,2 Samsung SGH-X495 Screen Replacement: 步骤 5 中的图像 2,2
      • Once the two side tabs are free; gently pry the white backing down to release the top two tabs.
      • Hold the phone with the left hand as shown
      • Wiggle the white backplate from side to side while pulling down with the right hand.
      询问修复机器人
      添加评论
    1. Samsung SGH-X495 Screen Replacement, Face Plate: 步骤 6 中的图像 1,1
      • First, remove the 2 silver stickers (as indicated by the circles) with a a safety or push pin to reveal 2 screws.
      询问修复机器人
      添加评论
    2. Samsung SGH-X495 Screen Replacement: 步骤 7 中的图像 1,1
      • Remove the 2 (5.6 mm) philips head screws with your safety or push pin.
      询问修复机器人
      添加评论
    3. Samsung SGH-X495 Screen Replacement: 步骤 8 中的图像 1,2 Samsung SGH-X495 Screen Replacement: 步骤 8 中的图像 2,2
      • As shown above, with a plastic pry tool, begin working at the top corner and down each side. The face plate has 10 tabs that hook into the phone's body.
      • Before removing the 2 tabs on the bottom, the 3 tabs on either side must be free first.
      • Note: The bottom 2 are the most challenging to remove.
      • Note: When reassembling start with the bottom two tabs.
      询问修复机器人
      添加评论
    4. Samsung SGH-X495 Screen Replacement: 步骤 9 中的图像 1,2 Samsung SGH-X495 Screen Replacement: 步骤 9 中的图像 2,2
      • Continue down each side toward the bottom with your pry tool.
      • Note: It may help to use multiple pry tools to help hold it open.
      • Second photo: location of the tabs.
      询问修复机器人
      添加评论
    5. Samsung SGH-X495 Screen Replacement: 步骤 10 中的图像 1,2 Samsung SGH-X495 Screen Replacement: 步骤 10 中的图像 2,2
      • With 8 tabs released, the face plate is nearly free.
      • With the phone in your left hand, gently wiggle the face plate from side to side and push the face place upward.
      • Note: A strip of double sided tape holds the faceplate, so expect some resistance
      询问修复机器人
      添加评论
    1. Samsung SGH-X495 Screen Replacement, Screen: 步骤 11 中的图像 1,1
      • Use an opening tool to gently lift the ribbon wire connection to the screen.
      询问修复机器人
      添加评论
    2. Samsung SGH-X495 Screen Replacement: 步骤 12 中的图像 1,1
      • Pull back the protective sticker to open access through the phones joint.
      询问修复机器人
      添加评论
    3. Samsung SGH-X495 Screen Replacement: 步骤 13 中的图像 1,1
      • Carefully feed ribbon wire through the phones joint.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Matthew Hove
于01/05/11注册
1,031 声望
创作了10篇指南
团队
Cal Poly, Team 3-40, Regan Winter 2011 Cal Poly, Team 3-40, Regan Winter 2011 的会员
CPSU-REGAN-W11S3G40
4 名成员
创作了90篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 24
总计 1,687
