跳转到主内容
加入维修社区 - 创建账户
Samsung SCH-A310 Keypad Replacement
你所需要的
    1. Samsung SCH-A310 Keypad Replacement, Antenna: 步骤 1 中的图像 1,1
      • Remove the battery by pressing the button at the top of the case.
      询问修复机器人
      添加评论
    2. Samsung SCH-A310 Keypad Replacement: 步骤 2 中的图像 1,3 Samsung SCH-A310 Keypad Replacement: 步骤 2 中的图像 2,3 Samsung SCH-A310 Keypad Replacement: 步骤 2 中的图像 3,3
      • Unscrew the antenna by twisting it counter-clockwise until it is loose.
      • Slide the antenna out of the phone.
      • The black casing can be removed from the old antenna and used for the new antenna.
      询问修复机器人
      添加评论
    1. Samsung SCH-A310 Keypad Replacement, Keypad: 步骤 3 中的图像 1,1
      • Using a #00 Phillips Screwdriver, remove the 4 (3mm) black screws from each corner of the back casing.
      • Place these screws in a safe place. If you can, try to loosen the screws without removing them entirely to help keep track of them, they are easy to lose.
      询问修复机器人
      添加评论
    2. Samsung SCH-A310 Keypad Replacement: 步骤 4 中的图像 1,3 Samsung SCH-A310 Keypad Replacement: 步骤 4 中的图像 2,3 Samsung SCH-A310 Keypad Replacement: 步骤 4 中的图像 3,3
      • Use the wide plastic prying tool to open the back case.
      • To make this process easier, use the tool to push against this tab while gently pulling the back upward.
      • Repeat this process on the opposite side.
      • The volume button may fall out, but don't force it back in. Set it aside for reassembly.
      • When replacing the volume button, the rubber tab must be placed carefully into the space in the inner casing.
      询问修复机器人
      添加评论
    3. Samsung SCH-A310 Keypad Replacement: 步骤 5 中的图像 1,3 Samsung SCH-A310 Keypad Replacement: 步骤 5 中的图像 2,3 Samsung SCH-A310 Keypad Replacement: 步骤 5 中的图像 3,3
      • Pull the back plate up by gently twisting slightly towards the top left corner. When you feel the catch release, you can fold the plate back like a book cover.
      • Be careful of the connectors. There are two very small wires which run to the back cover of the phone.
      • If you accidentally pull the wires out, don't panic. The connector can be pushed back into place very easily.
      • If you are confident in your ability to reassemble the device, pulling the connector out can make this process easier by getting the back casing out of the way.
      询问修复机器人
      添加评论
    4. Samsung SCH-A310 Keypad Replacement: 步骤 6 中的图像 1,2 Samsung SCH-A310 Keypad Replacement: 步骤 6 中的图像 2,2
      • Fold the circuit board back like a book cover just as you did with the back plate.
      • Be careful of this connector which goes to the front of the phone.
      • Unlike the connector in the previous step, this one should not be removed unless you plan to replace the motherboard.
      • The silver contacts on the bottom of the motherboard are what recognize key presses; if the phone isn't responding to key presses, you will need to replace the motherboard here.
      询问修复机器人
      添加评论
    5. Samsung SCH-A310 Keypad Replacement: 步骤 7 中的图像 1,1
      • Simply pop the keypad out of the case by pressing the keys through the frame.
      • If keys were sticky, give them a thorough cleaning with soap and water; if they are damaged, replace the keypad.
      • Make sure to dry the keypad very thoroughly before placing back in the frame.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Jacob
于01/20/12注册
1 声望
撰写一个指南
团队
Cal Poly, Team 11-23, Maness Winter 2012 Cal Poly, Team 11-23, Maness Winter 2012 的会员
CPSU-MANESS-W12S11G23
4 名成员
创作了45篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 21
总计 1,782
