跳转到主内容
加入维修社区 - 创建账户
Samsung SCH-3500 Back Cover Replacement
你所需要的
    1. Samsung SCH-3500 Back Cover Replacement, Battery: 步骤 1 中的图像 1,2 Samsung SCH-3500 Back Cover Replacement, Battery: 步骤 1 中的图像 2,2
      • Place the phone so that the back is facing you. Depress the locking tab on the back of the phone with a finger or thumb.
      询问修复机器人
      添加评论
    2. Samsung SCH-3500 Back Cover Replacement: 步骤 2 中的图像 1,1
      • Slide the battery toward bottom of the phone, about a quarter of an inch, to clear the hooks that keep it secured to the back of the phone.
      询问修复机器人
      添加评论
    3. Samsung SCH-3500 Back Cover Replacement: 步骤 3 中的图像 1,1
      • Lift the battery away from the phone case.
      询问修复机器人
      添加评论
    1. Samsung SCH-3500 Back Cover Replacement, Antenna: 步骤 4 中的图像 1,2 Samsung SCH-3500 Back Cover Replacement, Antenna: 步骤 4 中的图像 2,2
      • Grasp the antenna firmly and rotate it counterclockwise to unscrew it from the phone.
      询问修复机器人
      添加评论
    2. Samsung SCH-3500 Back Cover Replacement: 步骤 5 中的图像 1,1
      • When unscrewed, pull the antenna straight up and out.
      询问修复机器人
      添加评论
    3. Samsung SCH-3500 Back Cover Replacement: 步骤 6 中的图像 1,2 Samsung SCH-3500 Back Cover Replacement: 步骤 6 中的图像 2,2
      • Pull the guide tube free from its retaining ring and slide it out the top.
      询问修复机器人
      添加评论
    1. Samsung SCH-3500 Back Cover Replacement, Back Cover: 步骤 7 中的图像 1,1
      • Remove the four screws using a T6 Torx screwdriver.
      询问修复机器人
      添加评论
    2. Samsung SCH-3500 Back Cover Replacement: 步骤 8 中的图像 1,2 Samsung SCH-3500 Back Cover Replacement: 步骤 8 中的图像 2,2
      • Work from the bottom of the phone, separating the two halves of the case.
      • Note: Take care to keep the logic board with the front case half. Part of the logic board is exposed to the sticker under the battery on the rear case half.
      询问修复机器人
      添加评论
    3. Samsung SCH-3500 Back Cover Replacement: 步骤 9 中的图像 1,1
      • Angle the rear case half away from the top of the front case half, pivoting the hooks out of their clasps.
      • Caution: Do not fully separate the halves. There is an antenna ribbon connected to the logic board from the back cover.
      询问修复机器人
      添加评论
    4. Samsung SCH-3500 Back Cover Replacement: 步骤 10 中的图像 1,3 Samsung SCH-3500 Back Cover Replacement: 步骤 10 中的图像 2,3 Samsung SCH-3500 Back Cover Replacement: 步骤 10 中的图像 3,3
      • Disconnect the antenna ribbon cable from the logic board at the Zero Insertion Force (ZIF) connector. The brown portion of the connector lifts up to release the cable end.
      • The Back Cover is now removed. Congratulations.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Clemson, Team 2-6, Benson Spring 2012 Clemson, Team 2-6, Benson Spring 2012 的会员
CLEM-BENSON-S12S2G6
2 名成员
创作了35篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 28
总计 911
