跳转到主内容
加入维修社区 - 创建账户
Samsung Refrigerator Control Board Replacement
你所需要的
    1. Samsung Refrigerator Control Board Replacement, Unplug your refrigerator: 步骤 1 中的图像 1,1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      询问修复机器人
      添加评论
    1. Samsung Refrigerator Control Board Replacement, Remove the board access panel: 步骤 2 中的图像 1,1
      • Remove the screws securing the board access panel to the back of the refrigerator.
      询问修复机器人
      添加评论
    2. Samsung Refrigerator Control Board Replacement: 步骤 3 中的图像 1,2 Samsung Refrigerator Control Board Replacement: 步骤 3 中的图像 2,2
      • Remove the board access panel.
      询问修复机器人
      添加评论
    1. Samsung Refrigerator Control Board Replacement, Reassembly information: 步骤 4 中的图像 1,2 Samsung Refrigerator Control Board Replacement, Reassembly information: 步骤 4 中的图像 2,2
      • Note the locations and number of the connectors on the control board, and photograph them or draw a diagram. This example control board has nine wire connectors:
      • Three connectors along the top edge
      • One connector along the right edge
      • One connector along the bottom edge
      • Four connectors along the left edge
      • During reassembly, use your diagram or the photo you took (like the second image here) to make sure you've reconnected all of the connectors.
      询问修复机器人
      添加评论
    2. Samsung Refrigerator Control Board Replacement, Remove the control board: 步骤 5 中的图像 1,2 Samsung Refrigerator Control Board Replacement, Remove the control board: 步骤 5 中的图像 2,2
      • Pull and disconnect each of the connectors from the control board.
      • Some connectors may have a locking tab. Squeeze the wide sides of the connector to unlock it, then pull to disconnect it.
      • Move the wires away from the control board so it can swing out of its recess.
      询问修复机器人
      添加评论
    3. Samsung Refrigerator Control Board Replacement: 步骤 6 中的图像 1,3 Samsung Refrigerator Control Board Replacement: 步骤 6 中的图像 2,3 Samsung Refrigerator Control Board Replacement: 步骤 6 中的图像 3,3
      • Use your fingers to push up the plastic lip securing the top edge of the control board to the refrigerator.
      • Swing the control board out and remove it.
      添加评论
结论
Repair didn’t go as planned? Ask our Answers Community for help.
取消:我没有完成这个指南。
2等其他人完成本指南。
Bill Gilbert
于06/30/22注册
40,168 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了49,847篇指南
5指南评论
My tempura in my new refrigerator isn’t working right , I bought earlier this year
Carolyn whittaker - 回复 分享
Is this Samsung
Do you have a phone number
Samsung fridge- after changing a water filter, bottom drawer freezer stopped making ice.
It is set for 0 but no ice. I bought this fridge last year.
Sewell Nikki - 回复 分享
My refrigerator light is on but the comppresor is not working and anytime I on it is not piping sounds again
Asiafa - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 98
过去 30 天: 420
总计 9,172
