跳转到主内容
Samsung PL20 LCD Replacement
你所需要的
  1. Samsung PL20 LCD Replacement, LCD: 步骤 1 中的图像 1,3 Samsung PL20 LCD Replacement, LCD: 步骤 1 中的图像 2,3 Samsung PL20 LCD Replacement, LCD: 步骤 1 中的图像 3,3
    • Here is the broken LCD. The spider crack in the glass, as well as the discoloration of the screen, is clearly visible.
    • Remove the battery and the memory card from the device, if so equipped.
    • Remove the two screws on the left side.
  2. Samsung PL20 LCD Replacement: 步骤 2 中的图像 1,3 Samsung PL20 LCD Replacement: 步骤 2 中的图像 2,3 Samsung PL20 LCD Replacement: 步骤 2 中的图像 3,3
    • Remove one screw from the bottom
    • Remove the two screws on the right side.
    • Use a plastic opening tool, or your fingernails, to split the casing apart. Start from the battery compartment and work your way around the case. The case should split easily.
  3. Samsung PL20 LCD Replacement: 步骤 3 中的图像 1,3 Samsung PL20 LCD Replacement: 步骤 3 中的图像 2,3 Samsung PL20 LCD Replacement: 步骤 3 中的图像 3,3
    • Once the back of the case is removed, the LCD becomes immediately visible.
    • Remove the LCD from its holder to gain access to the connector.
    • Open the connector, and flip the black clip upwards, freeing the LCD. It can now be removed and the new one installed.
结论
7等其他人完成本指南。
oldturkey03
于09/29/10注册
836,440 声望
创作了123篇指南
1指南评论
Great help! Screen replaced no problem. Thank you
EE61 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 43
总计 4,050
