跳转到主内容
加入维修社区 - 创建账户
Samsung NP700Z5AH Display Replacement
你所需要的
  1. Samsung NP700Z5AH Display Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the ten 6.6mm Philips#00 screws securing the lower case to the upper case.
    询问修复机器人
    添加评论
  2. Samsung NP700Z5AH Display Replacement: 步骤 2 中的图像 1,3 Samsung NP700Z5AH Display Replacement: 步骤 2 中的图像 2,3 Samsung NP700Z5AH Display Replacement: 步骤 2 中的图像 3,3
    • Using your fingers, pinch the edge of the SD card and pull to remove it.
    询问修复机器人
    添加评论
  3. Samsung NP700Z5AH Display Replacement: 步骤 3 中的图像 1,2 Samsung NP700Z5AH Display Replacement: 步骤 3 中的图像 2,2
    • Wedge your fingers in between the upper case and the lower case
    • Gently pull the lower case away from the upper case to remove it
    询问修复机器人
    添加评论
  4. Samsung NP700Z5AH Display Replacement: 步骤 4 中的图像 1,2 Samsung NP700Z5AH Display Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Using tweezers or your fingertips, carefully pull on the battery connector to disconnect it from the motherboard.
    • Be sure to pull straight backwards, or you risk damaging the wires.
    添加评论
  5. Samsung NP700Z5AH Display Replacement: 步骤 5 中的图像 1,1
    • Remove the two 4.4mm Phillips#00 screws from the battery case.
    询问修复机器人
    添加评论
  6. Samsung NP700Z5AH Display Replacement: 步骤 6 中的图像 1,2 Samsung NP700Z5AH Display Replacement: 步骤 6 中的图像 2,2
    • Place your fingers on the corner sections of the battery.
    • Lift to remove the battery.
    • If you choose to use tools to remove the battery be careful not to damage it. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
    添加评论
  7. Samsung NP700Z5AH Display Replacement, Display: 步骤 7 中的图像 1,2 Samsung NP700Z5AH Display Replacement, Display: 步骤 7 中的图像 2,2
    • Place the tip of the spudger under the metal caps of the black and grey coaxial connectors and pry upwards to disconnect them.
    • After they are disconnected, un-thread the coaxial connectors from around the fan.
    • To reinstall, hold the connectors in place and gently press them straight down. The connectors "snap" into their sockets much like the metal snaps on a jacket.
    询问修复机器人
    添加评论
  8. Samsung NP700Z5AH Display Replacement: 步骤 8 中的图像 1,3 Samsung NP700Z5AH Display Replacement: 步骤 8 中的图像 2,3 Samsung NP700Z5AH Display Replacement: 步骤 8 中的图像 3,3
    • Using the Phillips#00, remove the single 3.5mm screw from the wireless card.
    • Grasp the edges of the wireless card with your fingers and pull straight backwards to remove it.
    询问修复机器人
    添加评论
  9. Samsung NP700Z5AH Display Replacement: 步骤 9 中的图像 1,2 Samsung NP700Z5AH Display Replacement: 步骤 9 中的图像 2,2
    • Using the Phillips#00, remove the six 4.5mm screws from the corner brackets holding the display to the inner case.
    询问修复机器人
    添加评论
  10. Samsung NP700Z5AH Display Replacement: 步骤 10 中的图像 1,3 Samsung NP700Z5AH Display Replacement: 步骤 10 中的图像 2,3 Samsung NP700Z5AH Display Replacement: 步骤 10 中的图像 3,3
    • Using your fingers, grasp the edges of the inner case then lift and pull away to separate it from the display.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 34
总计 1,268
