跳转到主内容
加入维修社区 - 创建账户
Samsung NP300E5C Screen Replacement
你所需要的
    1. Samsung NP300E5C Screen Replacement, Battery: 步骤 1 中的图像 1,1
      • Lay laptop down so that the bottom is facing the sky.
      询问修复机器人
      添加评论
    2. Samsung NP300E5C Screen Replacement: 步骤 2 中的图像 1,3 Samsung NP300E5C Screen Replacement: 步骤 2 中的图像 2,3 Samsung NP300E5C Screen Replacement: 步骤 2 中的图像 3,3
      • Push both tabs away from the center of the device.
      • While both are in the fully unlocked position, slide the battery out.
      询问修复机器人
      添加评论
    1. Samsung NP300E5C Screen Replacement, Screen: 步骤 3 中的图像 1,1
      • Turn the laptop over and open it so that you can see the keyboard and screen.
      • Using a Phillips #000 screwdriver, remove the two 4 mm Phillips #8 screws that are under the black covers on the front of your screen.
      • You can remove the black covers by simply pushing your screwdriver into them.
      询问修复机器人
      添加评论
    2. Samsung NP300E5C Screen Replacement: 步骤 4 中的图像 1,3 Samsung NP300E5C Screen Replacement: 步骤 4 中的图像 2,3 Samsung NP300E5C Screen Replacement: 步骤 4 中的图像 3,3
      • Insert the plastic opening tool into the seam on the top of the screen.
      • The seam is where the back screen cover and the plastic bezel around the edges of the screen meet.
      • Use the plastic opening tool to pop open the clasps that keep the casing on the screen.
      • It helps to use the plastic opening tool like a crowbar.
      • Follow this seam around the laptop's screen with the plastic opening tool until the plastic cover comes off.
      • Don't be afraid to use your fingers to help pop open the clips.
      询问修复机器人
      添加评论
    3. Samsung NP300E5C Screen Replacement: 步骤 5 中的图像 1,1
      • Using a Phillips #000 screwdriver, remove the top two 4 mm Phillips #8 screws that join the LCD screen to the plastic casing.
      • Using the same screwdriver, remove the bottom four 4 mm Phillips #8 screws that mount the screen onto the base of the laptop.
      • As you remove these bottom 4 screws, support the screen! As the screws come off, the screen will begin to fall backwards.
      添加评论
    4. Samsung NP300E5C Screen Replacement: 步骤 6 中的图像 1,3 Samsung NP300E5C Screen Replacement: 步骤 6 中的图像 2,3 Samsung NP300E5C Screen Replacement: 步骤 6 中的图像 3,3
      • Gently lay the LCD on the keyboard, and lay down the back panel of the screen as well. They are not attached and will separate easily.
      • The LCD and the back panel must remain close to one another due to the video connector at the bottom that links the two.
      • Remove the tape that secures the video connector to the LCD.
      • While maintaining a firm grip on the LCD, grasp the video connector at its base, and pull it away from you.
      • Don't be afraid to pull, the video connector is not soldered onto the LCD.
      添加评论
结论
取消:我没有完成这个指南。
10等其他人完成本指南。
aliahsan95
于09/23/15注册
937 声望
创作了4篇指南
团队
Baylor, Team 10-13, Williams Fall 2015 Baylor, Team 10-13, Williams Fall 2015 的会员
BU-WILLIAMS-F15S10G13
3 名成员
创作了36篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 64
总计 6,810
