跳转到主内容
加入维修社区 - 创建账户
Samsung Impression Back Speaker Replacement
你所需要的
    1. Samsung Impression Back Speaker Replacement, Battery: 步骤 1 中的图像 1,1
      • Orient the phone with the screen facing downward.
      • Slide the panel away from the camera using your thumb. This will expose the battery.
      询问修复机器人
      添加评论
    2. Samsung Impression Back Speaker Replacement: 步骤 2 中的图像 1,2 Samsung Impression Back Speaker Replacement: 步骤 2 中的图像 2,2
      • Insert the tip of the spudger on the left side of the battery.
      • Pry the battery out. It will pivot in the direction of the white arrow.
      询问修复机器人
      添加评论
    1. Samsung Impression Back Speaker Replacement, Back Cover: 步骤 3 中的图像 1,1
      • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
      询问修复机器人
      添加评论
    2. Samsung Impression Back Speaker Replacement: 步骤 4 中的图像 1,1
      • Gently pry around the edges with the spudger to remove back panel.
      • It may help to slide the touchscreen upwards when removing the back panel.
      • The side buttons will become loose and will fall out, so put these in a safe place.
      询问修复机器人
      添加评论
    1. Samsung Impression Back Speaker Replacement, Back Speaker: 步骤 5 中的图像 1,1
      • Carefully pry the back speaker upwards with a spudger.
      • The speaker is still connected to the circuit board by a wire and small piece of clear plastic.
      • Disconnect the speaker by lifting the clear plastic piece attached to the wire.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Cal Poly, Team 8-10, Regan Spring 2011 Cal Poly, Team 8-10, Regan Spring 2011 的会员
CPSU-REGAN-S11S8G10
4 名成员
创作了56篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 25
总计 2,448
