简介
Shows how to place LCD screen of the camera via words and pictures. Replacement of LCD screen requires the removal of motherboard.
你所需要的
To remove the wristband of the device, grab the middle loop and pull the band through.
Use tweezers to grab the wire ribbon, then pull the wire out of connection.
There are 5 Phillips size 00 screws. Remove all 5 screws.
Wire ribbon is attached to the motherboard.
Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
另外一个人完成了本指南。
