跳转到主内容
加入维修社区 - 创建账户
Samsung HMX-W200 Battery Replacement
你所需要的
    1. Samsung HMX-W200 Battery Replacement, Outer Case: 步骤 1 中的图像 1,1
      • Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
      添加评论
    2. Samsung HMX-W200 Battery Replacement: 步骤 2 中的图像 1,3 Samsung HMX-W200 Battery Replacement: 步骤 2 中的图像 2,3 Samsung HMX-W200 Battery Replacement: 步骤 2 中的图像 3,3
      • Use the plastic opening tool to separate and remove the bottom red casing. Do this by, pushing the tool into the seam and prying up the red casing as you move along the edges.
      • Make sure to separate all the corners before removing the red casing.
      询问修复机器人
      添加评论
    3. Samsung HMX-W200 Battery Replacement: 步骤 3 中的图像 1,2 Samsung HMX-W200 Battery Replacement: 步骤 3 中的图像 2,2
      • Using the plastic opening tool, separate and pull away the red casing on the right of the LCD screen.
      添加评论
    4. Samsung HMX-W200 Battery Replacement: 步骤 4 中的图像 1,2 Samsung HMX-W200 Battery Replacement: 步骤 4 中的图像 2,2
      • To access the HDMI slot, move slider towards the bottom of the casing on the other side of the camcorder. The lid casing will lift up upon doing so.
      • After accessing the HDMI slot you will find a 5.00mm screw. Using a Phillips #00 screwdriver, remove the screw.
      询问修复机器人
      添加评论
    5. Samsung HMX-W200 Battery Replacement: 步骤 5 中的图像 1,2 Samsung HMX-W200 Battery Replacement: 步骤 5 中的图像 2,2
      • Using the plastic opening tool, separate and pull away the red casing to the left of the LCD screen.
      询问修复机器人
      添加评论
    6. Samsung HMX-W200 Battery Replacement: 步骤 6 中的图像 1,2 Samsung HMX-W200 Battery Replacement: 步骤 6 中的图像 2,2
      • Remove the six 5.00mm screws by using a Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    7. Samsung HMX-W200 Battery Replacement: 步骤 7 中的图像 1,3 Samsung HMX-W200 Battery Replacement: 步骤 7 中的图像 2,3 Samsung HMX-W200 Battery Replacement: 步骤 7 中的图像 3,3
      • Lift the two plastic tabs on the left side of the LCD screen and the single one on the right side on the black casing to open the device.
      询问修复机器人
      添加评论
    8. Samsung HMX-W200 Battery Replacement: 步骤 8 中的图像 1,1
      • Separate the front and back casing.
      询问修复机器人
      添加评论
    1. Samsung HMX-W200 Battery Replacement, Battery: 步骤 9 中的图像 1,2 Samsung HMX-W200 Battery Replacement, Battery: 步骤 9 中的图像 2,2
      • Remove the four 4.00mm screws holding the battery brace using a Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    2. Samsung HMX-W200 Battery Replacement: 步骤 10 中的图像 1,1
      • Using a plastic opening tool, lift the copper tab holding the battery brace in place.
      询问修复机器人
      添加评论
    3. Samsung HMX-W200 Battery Replacement: 步骤 11 中的图像 1,2 Samsung HMX-W200 Battery Replacement: 步骤 11 中的图像 2,2
      • Remove the battery brace and battery from the camera casing.
      • Remove the old battery from the brace and place the new one.
      • Your battery might be held to the brace by a copper tape. If so, you'll need to peel the tape away to remove it. This tape does not affect the battery's operation in any way, so it is safe to remove it.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
USF Tampa, Team 3-6, Sullivan Fall 2016 USF Tampa, Team 3-6, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S3G6
4 名成员
创作了13篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 35
总计 1,447
