跳转到主内容
加入维修社区 - 创建账户
Samsung Gravity TXT Volume Rocker Replacement
你所需要的
  1. Samsung Gravity TXT Volume Rocker Replacement, Battery: 步骤 1 中的图像 1,2 Samsung Gravity TXT Volume Rocker Replacement, Battery: 步骤 1 中的图像 2,2
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
    询问修复机器人
    添加评论
  2. Samsung Gravity TXT Volume Rocker Replacement: 步骤 2 中的图像 1,1
    • Lift the back cover away from the main body of the phone.
    添加评论
  3. Samsung Gravity TXT Volume Rocker Replacement: 步骤 3 中的图像 1,1
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
    询问修复机器人
    添加评论
  4. Samsung Gravity TXT Volume Rocker Replacement, SIM Card: 步骤 4 中的图像 1,3 Samsung Gravity TXT Volume Rocker Replacement, SIM Card: 步骤 4 中的图像 2,3 Samsung Gravity TXT Volume Rocker Replacement, SIM Card: 步骤 4 中的图像 3,3
    • Using your finger, push the SIM Card down and slide out of the slot.
    • Slide the SIM card out enough to grab it firmly.
    • Remove the SIM card away from the phone.
    • Follow the visual on the bottom of the SIM card slot to put the SIM card back in the correct orientation.
    • When sliding the SIM Card back in the slot, make sure the card goes all the way in the slot until it hits the stopper.
    询问修复机器人
    添加评论
  5. Samsung Gravity TXT Volume Rocker Replacement, microSD Card: 步骤 5 中的图像 1,3 Samsung Gravity TXT Volume Rocker Replacement, microSD Card: 步骤 5 中的图像 2,3 Samsung Gravity TXT Volume Rocker Replacement, microSD Card: 步骤 5 中的图像 3,3
    • Using your fingernail, push the microSD card slightly deeper into the slot, until you hear a click.
    • The removal of the battery is not required for this operation; therefore, step 3 can be skipped if just replacing the microSD card.
    • After the click, release the microSD card to allow it to pop out.
    • Remove the microSD card from its slot
    • When placing the microSD card back in the phone, make sure the card clicks in place.
    询问修复机器人
    添加评论
  6. Samsung Gravity TXT Volume Rocker Replacement, Plastic Back Frame: 步骤 6 中的图像 1,1
    • Remove the six 3 mm #00 Phillips screws in the plastic back frame.
    询问修复机器人
    添加评论
  7. Samsung Gravity TXT Volume Rocker Replacement: 步骤 7 中的图像 1,3 Samsung Gravity TXT Volume Rocker Replacement: 步骤 7 中的图像 2,3 Samsung Gravity TXT Volume Rocker Replacement: 步骤 7 中的图像 3,3
    • Slide the keyboard out.
    • Use a Jimmy to separate a small segment of the plastic back frame from rest of the phone.
    • Starting at the bottom of the keyboard is recommended.
    • Slide an opening pick around the rest of the seam, starting at the gap just created with the Jimmy.
    • You will have to slide the keyboard back in to separate the back frame from the top have of the keyboard slider.
    • Lift the plastic back frame away.
    询问修复机器人
    添加评论
  8. Samsung Gravity TXT Volume Rocker Replacement, Volume Rocker: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    • Unhook the volume rocker tether with a pair of tweezers or the pointed end of a spudger.
    • The button and tether will be in the plastic back frame
    询问修复机器人
    添加评论
  9. Samsung Gravity TXT Volume Rocker Replacement: 步骤 9 中的图像 1,2 Samsung Gravity TXT Volume Rocker Replacement: 步骤 9 中的图像 2,2
    • Push the + end of the volume rocker toward the inside of the back frame until it rolls over the "+ end" retainer feature on the frame.
    • You may have to use the back end of a plastic opening tool or solid object to press the + side far enough to release it.
    • New line.Lift the button out of its slot in the frame.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Josh Brown
于07/07/15注册
222 声望
创作了2篇指南
团队
IUPUI, Team 1-1, Renguette SU 2015 IUPUI, Team 1-1, Renguette SU 2015 的会员
IUPUI-RENGUETTE-SU15S1G1
5 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 471
