跳转到主内容
加入维修社区 - 创建账户
Samsung Gravity TXT SIM Card Replacement
你所需要的
  1. Samsung Gravity TXT SIM Card Replacement, Battery: 步骤 1 中的图像 1,2 Samsung Gravity TXT SIM Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
    询问修复机器人
    添加评论
  2. Samsung Gravity TXT SIM Card Replacement: 步骤 2 中的图像 1,1
    • Lift the back cover away from the main body of the phone.
    添加评论
  3. Samsung Gravity TXT SIM Card Replacement: 步骤 3 中的图像 1,1
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
    询问修复机器人
    添加评论
  4. Samsung Gravity TXT SIM Card Replacement, SIM Card: 步骤 4 中的图像 1,3 Samsung Gravity TXT SIM Card Replacement, SIM Card: 步骤 4 中的图像 2,3 Samsung Gravity TXT SIM Card Replacement, SIM Card: 步骤 4 中的图像 3,3
    • Using your finger, push the SIM Card down and slide out of the slot.
    • Slide the SIM card out enough to grab it firmly.
    • Remove the SIM card away from the phone.
    • Follow the visual on the bottom of the SIM card slot to put the SIM card back in the correct orientation.
    • When sliding the SIM Card back in the slot, make sure the card goes all the way in the slot until it hits the stopper.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
IUPUI, Team 1-1, Renguette SU 2015 IUPUI, Team 1-1, Renguette SU 2015 的会员
IUPUI-RENGUETTE-SU15S1G1
5 名成员
创作了32篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 38
总计 1,228
