跳转到主内容
加入维修社区 - 创建账户
Samsung Gear VR USB Connector Replacement
    1. Samsung Gear VR USB Connector Replacement, USB Connector Replacement: 步骤 1 中的图像 1,1
      • Remove front cover from headset.
      询问修复机器人
      添加评论
    2. Samsung Gear VR USB Connector Replacement: 步骤 2 中的图像 1,1
      • Slide the latch to the right to unlock the current connector.
      添加评论
    3. Samsung Gear VR USB Connector Replacement: 步骤 3 中的图像 1,2 Samsung Gear VR USB Connector Replacement: 步骤 3 中的图像 2,2
      • Lift connector clip away from headset and towards you.
      • Slide current connector out and away from headset until it is disconnected from connector clip.
      询问修复机器人
      添加评论
    4. Samsung Gear VR USB Connector Replacement: 步骤 4 中的图像 1,1
      • Select which connector fits the port of the device you wish to use with the Samsung Gear VR.
      • The Samsung Gear VR is packaged with connectors for Micro USB and USB-C.
      询问修复机器人
      添加评论
    5. Samsung Gear VR USB Connector Replacement: 步骤 5 中的图像 1,2 Samsung Gear VR USB Connector Replacement: 步骤 5 中的图像 2,2
      • Slide the connector that connects to your device back onto the connector clip until you feel it settle into place.
      • Slide the lock latch to the left to secure the connector into place.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
USF Tampa, Team S4-G6, Eyestone Fall 2017 USF Tampa, Team S4-G6, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S4G6
4 名成员
创作了14篇指南
5指南评论
Hola, quisiera saber donde se consigue esa parte, ni siquiera en samsung lo he logrado
Jose Davinci - 回复 分享
Were do I get the USB c adapter
helenpaul77 - 回复 分享
If you want USB c adapter I can give you…but we have to make exchange because I need micro usb adapter not type c
Molefi Aaron - 回复 分享
I have the micro USB adapter and need type c. Please advise as to how this barter may be executed?
Saleem A. Sheikh - 回复 分享
Where can I get micro USB converter for gear vr not type c
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 98
总计 18,244
