跳转到主内容
加入维修社区 - 创建账户
Samsung Gear VR Lens Replacement
你所需要的
  1. Samsung Gear VR Lens Replacement, Front Phone Mount: 步骤 1 中的图像 1,3 Samsung Gear VR Lens Replacement, Front Phone Mount: 步骤 1 中的图像 2,3 Samsung Gear VR Lens Replacement, Front Phone Mount: 步骤 1 中的图像 3,3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
    询问修复机器人
    添加评论
  2. Samsung Gear VR Lens Replacement: 步骤 2 中的图像 1,2 Samsung Gear VR Lens Replacement: 步骤 2 中的图像 2,2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
    询问修复机器人
    添加评论
  3. Samsung Gear VR Lens Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
    询问修复机器人
    添加评论
  4. Samsung Gear VR Lens Replacement: 步骤 4 中的图像 1,1
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
    询问修复机器人
    添加评论
  5. Samsung Gear VR Lens Replacement, Inner Mask: 步骤 5 中的图像 1,3 Samsung Gear VR Lens Replacement, Inner Mask: 步骤 5 中的图像 2,3 Samsung Gear VR Lens Replacement, Inner Mask: 步骤 5 中的图像 3,3
    • Using the PH000 tip remove the eight 0.5 cm screws from the Inner Mask
    • Carefully remove the Inner Mask by pulling it from the inner side of the lenses socket.
    询问修复机器人
    添加评论
  6. Samsung Gear VR Lens Replacement, Lens: 步骤 6 中的图像 1,2 Samsung Gear VR Lens Replacement, Lens: 步骤 6 中的图像 2,2
    • Using the metal spudger, push in the 3 tabs around the lens housing to release the lens. Repeat for both lens for a total of 6 tabs.
    • Do not push in too hard or you might brake the tabs.
    询问修复机器人
    添加评论
  7. Samsung Gear VR Lens Replacement: 步骤 7 中的图像 1,1
    • Flip the headgear and use your fingers to gently remove lens from mask. Repeat for both lens.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
USF Tampa, Team S4-G6, Eyestone Fall 2017 USF Tampa, Team S4-G6, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S4G6
4 名成员
创作了14篇指南
1指南评论
There are multiple mistakes in this tutorial, which made it hard to follow the steps:
- in step 2.1, you are missing 4 screws below each side of the latching mechanism.
- in step 5, the mask does not come apart after unscrewing the 8 screws. I am currently stuck at this step as I am writing this. Wish me luck.
L.H. - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 37
总计 6,832
