跳转到主内容
加入维修社区 - 创建账户
Samsung Gear 2 Battery Replacement
你所需要的
    1. Samsung Gear 2 Battery Replacement, Front half and Back half: 步骤 1 中的图像 1,2 Samsung Gear 2 Battery Replacement, Front half and Back half: 步骤 1 中的图像 2,2
      • Before disassembling your Gear, be sure it is powered off.
      • To remove each strap, locate the metal latches on both sides of the back of the Gear.
      • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
      询问修复机器人
      添加评论
    2. Samsung Gear 2 Battery Replacement: 步骤 2 中的图像 1,1
      • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
      询问修复机器人
      添加评论
    3. Samsung Gear 2 Battery Replacement: 步骤 3 中的图像 1,3 Samsung Gear 2 Battery Replacement: 步骤 3 中的图像 2,3 Samsung Gear 2 Battery Replacement: 步骤 3 中的图像 3,3
      • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
      • Pry the device open from the other side also if it does not fully disassemble from one side.
      询问修复机器人
      添加评论
    1. Samsung Gear 2 Battery Replacement, Battery: 步骤 4 中的图像 1,2 Samsung Gear 2 Battery Replacement, Battery: 步骤 4 中的图像 2,2
      • Use the pointed side of the spudger to remove the small, orange battery cable.
      添加评论
    2. Samsung Gear 2 Battery Replacement: 步骤 5 中的图像 1,2 Samsung Gear 2 Battery Replacement: 步骤 5 中的图像 2,2
      • Remove the battery by pulling the white tab on the battery marked "PULL."
      • Make sure the orange battery cable is fully disconnected to avoid ripping it off and tearing it.
      添加评论
结论
取消:我没有完成这个指南。
26等其他人完成本指南。
团队
Cal Poly, Team 13-27, Maness Spring 2014 Cal Poly, Team 13-27, Maness Spring 2014 的会员
CPSU-MANESS-S14S13G27
4 名成员
创作了6篇指南
15指南评论
Where can one find said replacement battery. I had it on in less than a meter of water for less than 30 minutes and water was able to get in. Even though I did not subject it to its supposed limitations I am fairly certain that best buy or samsung will check the water indicator paper and tell me that it was my fault. I have taken it apart and gotten it all dried out. It will come on and function just fine and then when i unplug it it will turn off after a minute or so. At any rate, I would like to replace my battery but need to find one first.
paul - 回复 分享
Where can I find a battery I have looked everywhere including Ebay and Amazon?
Mike Landriault - 回复 分享
I am looking for a battery also mine is very bad after 1 year. Were you able to find one?
Mimo Caceres - 回复 分享
We're can I find a replacement battery for my gear 2 neo watch looked everywhere
Drock - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 49
总计 59,429
