跳转到主内容
Samsung Galaxy Watch Battery Replacement
你所需要的
  1. Samsung Galaxy Watch Battery Replacement, Opening Procedure: 步骤 1 中的图像 1,1
    • Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
  2. Samsung Galaxy Watch Battery Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Watch Battery Replacement: 步骤 2 中的图像 2,2
    • Use an opening tool to get between the back cover and the metal housing of the watch.
    • Carefully pry the plastic back cover open.
    • Don't remove the back cover yet. There is a flex cable running to the core assembly inside.
  3. Samsung Galaxy Watch Battery Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Watch Battery Replacement: 步骤 3 中的图像 2,2
    • Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
  4. Samsung Galaxy Watch Battery Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Watch Battery Replacement: 步骤 4 中的图像 2,2
    • Use a spudger to disconnect the sensor flex cable from the motherboard.
  5. Samsung Galaxy Watch Battery Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Watch Battery Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Watch Battery Replacement: 步骤 5 中的图像 3,3
    • Remove the back cover.
    • When closing the watch make sure the rubber gasket is undamaged or replace it with a new one.
  6. Samsung Galaxy Watch Battery Replacement, Core Assembly Removal: 步骤 6 中的图像 1,2 Samsung Galaxy Watch Battery Replacement, Core Assembly Removal: 步骤 6 中的图像 2,2
    • Use a spudger to disconnect the display flex cable from the motherboard.
  7. Samsung Galaxy Watch Battery Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy Watch Battery Replacement: 步骤 7 中的图像 2,2
    • Lift the core unit out of the housing.
    • The core's plastic frame sits tight inside the housing.
    • Carefully thread the display flex cable through the gap of the core's plastic frame.
  8. Samsung Galaxy Watch Battery Replacement, Motherboard: 步骤 8 中的图像 1,2 Samsung Galaxy Watch Battery Replacement, Motherboard: 步骤 8 中的图像 2,2
    • Use a spudger to disconnect the hall sensor flex cable.
  9. Samsung Galaxy Watch Battery Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy Watch Battery Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy Watch Battery Replacement: 步骤 9 中的图像 3,3
    • Use a pair of tweezers to gently peel both button cables from the plastic frame.
  10. Samsung Galaxy Watch Battery Replacement: 步骤 10 中的图像 1,1
    • Remove the single Phillips #00 screw (3.4 mm length).
  11. Samsung Galaxy Watch Battery Replacement: 步骤 11 中的图像 1,3 Samsung Galaxy Watch Battery Replacement: 步骤 11 中的图像 2,3 Samsung Galaxy Watch Battery Replacement: 步骤 11 中的图像 3,3
    • Insert a spudger into the small gap underneath the motherboard where the cutout in the plastic frame is.
    • Lift the motherboard by twisting the spudger.
    • Slide the motherboard out from under the plastic tab.
  12. Samsung Galaxy Watch Battery Replacement: 步骤 12 中的图像 1,1
    • Remove the motherboard.
  13. Samsung Galaxy Watch Battery Replacement, Battery: 步骤 13 中的图像 1,3 Samsung Galaxy Watch Battery Replacement, Battery: 步骤 13 中的图像 2,3 Samsung Galaxy Watch Battery Replacement, Battery: 步骤 13 中的图像 3,3
    • Push the battery out of its recess through the cutout in the plastic frame.
    • The battery cable may slightly stick to the plastic frame—pull carefully.
    • Remove the battery.
结论
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
99等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
109,704 声望
创作了188篇指南
团队
iFixit iFixit 的会员
Community
141 名成员
创作了17,743篇指南
42条评论
thank you,it really help alot
Otunla oluwashina - 回复
Where can I buy the battery?
Buzz Burrows - 回复
Where can you buy the battery 42mm version?
Thomas - 回复
We hope to have them in our store soon. Check on our Samsung smartwatch parts over at https://www.ifixit.com/Store/Parts/Samsu...
Tobias Isakeit -
How much does this cost for a battery and labor
Audrey Snit - 回复
添加评论
浏览统计数据:
过去 24 小时: 191
过去 7 天: 1,128
过去 30 天: 5,504
总计 198,851
