跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy View Camera Replacement
你所需要的
    1. Samsung Galaxy View Camera Replacement, Kickstand: 步骤 1 中的图像 1,1
      • Place the device on a hard flat surface with its screen facing downwards.
      • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
      询问修复机器人
      添加评论
    2. Samsung Galaxy View Camera Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy View Camera Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy View Camera Replacement: 步骤 2 中的图像 3,3
      • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
      • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
      • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
      • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
      询问修复机器人
      添加评论
    1. Samsung Galaxy View Camera Replacement, Battery: 步骤 3 中的图像 1,2 Samsung Galaxy View Camera Replacement, Battery: 步骤 3 中的图像 2,2
      • Check the device is completely turned off.
      • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
      询问修复机器人
      添加评论
    2. Samsung Galaxy View Camera Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy View Camera Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy View Camera Replacement: 步骤 4 中的图像 3,3
      • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
      询问修复机器人
      添加评论
    3. Samsung Galaxy View Camera Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy View Camera Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy View Camera Replacement: 步骤 5 中的图像 3,3
      • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
      • Insert the metal spudger within the opening.
      • Move the metal spudger down the seam, prying the back panel open as you go.
      • Once a large enough opening is made, pry the entire back panel off with your hand.
      • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
      询问修复机器人
      添加评论
    4. Samsung Galaxy View Camera Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy View Camera Replacement: 步骤 6 中的图像 2,2
      • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
      询问修复机器人
      添加评论
    5. Samsung Galaxy View Camera Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy View Camera Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy View Camera Replacement: 步骤 7 中的图像 3,3
      • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
      • Remove the battery from the device.
      添加评论
    1. Samsung Galaxy View Camera Replacement, Camera: 步骤 8 中的图像 1,3 Samsung Galaxy View Camera Replacement, Camera: 步骤 8 中的图像 2,3 Samsung Galaxy View Camera Replacement, Camera: 步骤 8 中的图像 3,3
      • Place the plastic opening tool underneath the blue press-fit connector which is touching the green circuit board at the bottom of the device.
      • Pry upwards with the plastic opening tool to disconnect the press-fit connector.
      • Remove the camera by carefully gripping the press-fit connector and pulling upwards.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team 4-5, Livingston Fall 2016 Cal Poly, Team 4-5, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S4G5
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 23
总计 1,395
