跳转到主内容
Samsung Galaxy S8 Plus Display Adhesive Replacement
你所需要的
  1. Samsung Galaxy S8 Plus Display Adhesive Replacement, Display Adhesive: 步骤 1 中的图像 1,3 Samsung Galaxy S8 Plus Display Adhesive Replacement, Display Adhesive: 步骤 1 中的图像 2,3 Samsung Galaxy S8 Plus Display Adhesive Replacement, Display Adhesive: 步骤 1 中的图像 3,3
    • Remove all traces of adhesive and debris from the phone's frame. Clean the adhesion surface with high concentration isopropyl alcohol (over 90%) and wipe it clean with a lint-free cloth.
    • If glue or glass remnants are left behind, the new display will not mount correctly and may be damaged.
    • Lay the adhesive strips out to get an idea of where they go.
    • Peel off the clear plastic backing from the large pre-cut adhesive strip, exposing one side of adhesive.
  2. Samsung Galaxy S8 Plus Display Adhesive Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy S8 Plus Display Adhesive Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy S8 Plus Display Adhesive Replacement: 步骤 2 中的图像 3,3
    • Carefully line up a long edge of the adhesive with the edge of the phone frame.
    • Make sure that the adhesive cutouts match the phone's.
    • Set the adhesive down lightly on the frame.
    • If it is not properly aligned, carefully peel the adhesive back up.
    • Once the adhesive is aligned, use your fingers to press the adhesive onto the frame.
  3. Samsung Galaxy S8 Plus Display Adhesive Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy S8 Plus Display Adhesive Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy S8 Plus Display Adhesive Replacement: 步骤 3 中的图像 3,3
    • Peel one of the end adhesive strips from the clear plastic backing.
    • The strips are cut for a specific end and are not interchangeable.
    • Hold the strip by the two green end tabs and line the adhesive strip with the phone frame.
    • Lay the adhesive down lightly on the phone. Make sure that all cutouts are properly aligned.
    • Once aligned, use your fingers to press the adhesive into place.
    • Repeat the procedure for the remaining adhesive strip.
  4. Samsung Galaxy S8 Plus Display Adhesive Replacement: 步骤 4 中的图像 1,1
    • Continue reassembling your device until you are ready to attach the screen.
    • If possible, test your screen's functionality before sticking it in place.
    • Peel and remove the green plastic liner from all adhesive strips to expose the screen-facing adhesive.
    • Align and set the phone screen on top of the adhesive.
    • Use your fingers to squeeze around the perimeter of the phone to set the adhesive.
    • Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
结论
Follow this link to return to the Galaxy S8+ screen replacement guide.
8等其他人完成本指南。
Arthur Shi
于01/03/18注册
258,910 声望
创作了531篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,074篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 60
总计 6,260
