简介
Follow this guide to replace the display on your Samsung Galaxy S6. The assembly consists of an AMOLED and digitizer panel. The components are fused and must be replaced together. This procedure is useful for fixing broken glass or unresponsive touchscreens.
This guide instructs you to replace only the display while leaving the original frame, logic board, and battery in place. Note: some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires you to transplant all of your phone's internals and install a new battery. This procedure is very different, so make sure you have the correct part before starting this guide.
If the frame is damaged or bent, it's important to replace it, or else the new screen may not mount correctly and can suffer damage from uneven pressure.
This guide involves removing the rear glass. Removing the rear glass destroys the adhesive holding it in place. Follow this guide to reinstall the rear glass.
The process of separating the display from the frame usually destroys the display, so don't follow this guide unless you intend to replace the display.
你所需要的
Insert a paper clip or SIM eject tool into the hole in the SIM card slot on the power button side of the phone.
Press to eject the SIM card tray.
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Lay the heated iOpener over the rear panel for about two minutes to loosen the adhesive around the edge of the glass.
Shift the iOpener to heat the remaining section of the panel for another two minutes.
在这个步骤中使用的工具:Tweezers$4.99
Use tweezers to peel away any remaining adhesive from the phone's chassis.
Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Remove the thirteen 3.5mm Phillips #00 screws securing the midframe to the phone.
Firmly grasp the edge of the midframe assembly.
Lift up on the midframe assembly while pushing down on the battery to separate the midframe assembly from the rest of the phone.
While lifting the midframe, be careful to avoid snagging it on the audio jack or charging port.
Once the midframe is partially seperated, carefully run an opening pick around the edges of the rest of the phone to separate the top of the midframe.
To avoid damage to the headphone jack, remove the top of the midframe first, then push the midframe downwards to disengage it from the headphone jack.
You may need to heat and apply an iOpener to the edges of the display to soften the display adhesive if midframe separation is difficult.
Use the flat end of the spudger to disconnect the battery connector from its socket on the motherboard.
Use the pointed edge of a spudger to disconnect the Bluetooth and Wi-Fi antenna cable connectors from their sockets on the motherboard.
If your display glass is badly cracked, tape over the glass to contain stray glass and make prying easier.
Reheat the iOpener.
Lay the iOpener across the S6 display. After two minutes, shift the iOpener to the other half of the screen.
Slide the pick down the edge of the display to separate the adhesive underneath.
Stop cutting when you get to the daughterboard to avoid the delicate capacitive button under the display.
After cutting the adhesive, leave the pick in the side of the display to prevent the display from re-adhering to the frame.
To reassemble your device, follow these instructions in reverse order. When reinstalling the rear glass, refer to the rear glass adhesive replacement guide.
292等其他人完成本指南。
6条评论
I replaced my screen now my service doesn't work as well as it did before. What could I have missed.?
First thing you want to do is make sure that all the cables and wiring are in place on your device's logic board. I have seen this several times in my cell phone repair history.
If that step does not fix the issues then you want to change refer to the Samsung Support site about No Signal issues.
Latent or low service bars after you remove the mid-frame from outer frame is due to contacts within the outer frame not making the proper contact with the board. You can test service outside the frame which is one to two bars and very difficult to make calls. Once refit to the frame properly the service is boosted. If you are having service issues, its more than likely the frame. Take apart and check the inner frame and reassemble. Check service before you replace the back screws and glass battery door.
at step 18 make sure all of your motherboard components are free, my headphone jack got stuck on the frame and i nearly ripped the whole thing off
Note: a good test for broken OLED is to shine a UV light at it.
Broken units typically do not fluoresce corectly and show red “patches” where water has got in.
If you compare with a known good unit the difference is very obvious.
Note: if someone has changed the glass and used third party LOCA it will light up blue not white!
