跳转到主内容
Samsung Galaxy S21 Wireless Charging Coil Replacement
你所需要的
  1. Samsung Galaxy S21 Wireless Charging Coil Replacement, Heat the bottom edge: 步骤 1 中的图像 1,1
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display, internal battery, and plastic back cover are both susceptible to heat damage.
  2. Samsung Galaxy S21 Wireless Charging Coil Replacement, Separate the bottom adhesive: 步骤 2 中的图像 1,3 Samsung Galaxy S21 Wireless Charging Coil Replacement, Separate the bottom adhesive: 步骤 2 中的图像 2,3 Samsung Galaxy S21 Wireless Charging Coil Replacement, Separate the bottom adhesive: 步骤 2 中的图像 3,3
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
    • Only insert the pick up to 5 mm, as you may damage internal components if you go further.
  3. Samsung Galaxy S21 Wireless Charging Coil Replacement, Slice the bottom adhesive: 步骤 3 中的图像 1,3 Samsung Galaxy S21 Wireless Charging Coil Replacement, Slice the bottom adhesive: 步骤 3 中的图像 2,3 Samsung Galaxy S21 Wireless Charging Coil Replacement, Slice the bottom adhesive: 步骤 3 中的图像 3,3
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick in to prevent the adhesive from resealing.
  4. Samsung Galaxy S21 Wireless Charging Coil Replacement, Heat the left edge: 步骤 4 中的图像 1,1
    • Apply a heated iOpener to the back cover's left edge for two minutes.
  5. Samsung Galaxy S21 Wireless Charging Coil Replacement, Separate the left adhesive: 步骤 5 中的图像 1,3 Samsung Galaxy S21 Wireless Charging Coil Replacement, Separate the left adhesive: 步骤 5 中的图像 2,3 Samsung Galaxy S21 Wireless Charging Coil Replacement, Separate the left adhesive: 步骤 5 中的图像 3,3
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
  6. Samsung Galaxy S21 Wireless Charging Coil Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy S21 Wireless Charging Coil Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy S21 Wireless Charging Coil Replacement: 步骤 6 中的图像 3,3
    • Slide an opening pick along the left edge towards the bottom left corner to cut the adhesive.
    • Don't cut past where the camera shell meets the back cover, as you risk cracking the plastic.
  7. Samsung Galaxy S21 Wireless Charging Coil Replacement, Heat the right edge: 步骤 7 中的图像 1,1
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  8. Samsung Galaxy S21 Wireless Charging Coil Replacement, Separate the right adhesive: 步骤 8 中的图像 1,3 Samsung Galaxy S21 Wireless Charging Coil Replacement, Separate the right adhesive: 步骤 8 中的图像 2,3 Samsung Galaxy S21 Wireless Charging Coil Replacement, Separate the right adhesive: 步骤 8 中的图像 3,3
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Only insert the pick up to 3 mm, as you may damage the secondary interconnect cable, which runs parallel to the right edge.
  9. Samsung Galaxy S21 Wireless Charging Coil Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy S21 Wireless Charging Coil Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy S21 Wireless Charging Coil Replacement: 步骤 9 中的图像 3,3
    • Slide an opening pick back and forth along the back cover's right edge to cut the adhesive.
  10. Samsung Galaxy S21 Wireless Charging Coil Replacement, Separate the corner adhesive: 步骤 10 中的图像 1,3 Samsung Galaxy S21 Wireless Charging Coil Replacement, Separate the corner adhesive: 步骤 10 中的图像 2,3 Samsung Galaxy S21 Wireless Charging Coil Replacement, Separate the corner adhesive: 步骤 10 中的图像 3,3
    • Rotate the right-edge opening pick around the top-right corner of the phone.
    • This procedure can be applied to each corner, except the top-left where the rear-facing camera is located.
  11. Samsung Galaxy S21 Wireless Charging Coil Replacement, Reposition the opening picks: 步骤 11 中的图像 1,3 Samsung Galaxy S21 Wireless Charging Coil Replacement, Reposition the opening picks: 步骤 11 中的图像 2,3 Samsung Galaxy S21 Wireless Charging Coil Replacement, Reposition the opening picks: 步骤 11 中的图像 3,3
    • Slide the top-most opening pick as close to the camera shell as possible.
    • Repeat for the left-edge pick.
  12. Samsung Galaxy S21 Wireless Charging Coil Replacement, Heat the camera shell: 步骤 12 中的图像 1,1
    • Heat an iOpener and apply it to the camera shell for two minutes.
  13. Samsung Galaxy S21 Wireless Charging Coil Replacement, Separate the camera shell adhesive: 步骤 13 中的图像 1,3 Samsung Galaxy S21 Wireless Charging Coil Replacement, Separate the camera shell adhesive: 步骤 13 中的图像 2,3 Samsung Galaxy S21 Wireless Charging Coil Replacement, Separate the camera shell adhesive: 步骤 13 中的图像 3,3
    • Rotate the back cover counterclockwise to create a gap between the camera shell and the frame.
    • Only insert the pick up to 5 mm to avoid scratching the camera.
    • Insert an opening pick in the gap.
    • If this method doesn't work, move to the next step for an alternative method; otherwise, skip the next step.
  14. Samsung Galaxy S21 Wireless Charging Coil Replacement, Separate the camera shell adhesive (alternate method): 步骤 14 中的图像 1,3 Samsung Galaxy S21 Wireless Charging Coil Replacement, Separate the camera shell adhesive (alternate method): 步骤 14 中的图像 2,3 Samsung Galaxy S21 Wireless Charging Coil Replacement, Separate the camera shell adhesive (alternate method): 步骤 14 中的图像 3,3
    • Gently slide the two picks toward the camera shell so they are under the corners of the back cover adjacent to the camera shell.
    • Move the picks back and forth along the bridge between the back cover and the camera shell until you create a gap between the camera shell and the frame.
    • Be careful with this method, as you risk cracking the plastic back cover.
  15. Samsung Galaxy S21 Wireless Charging Coil Replacement: 步骤 15 中的图像 1,3 Samsung Galaxy S21 Wireless Charging Coil Replacement: 步骤 15 中的图像 2,3 Samsung Galaxy S21 Wireless Charging Coil Replacement: 步骤 15 中的图像 3,3
    • Slide an opening pick between the camera shell and the frame to cut the adhesive.
    • There's a significant amount of adhesive securing the frame to the camera shell, so multiple rounds of heating may be needed.
  16. Samsung Galaxy S21 Wireless Charging Coil Replacement: 步骤 16 中的图像 1,2 Samsung Galaxy S21 Wireless Charging Coil Replacement: 步骤 16 中的图像 2,2
    • There's additional adhesive to the right of the camera that you need to cut through.
    • There's a plate on the back cover surrounding the phone's flash that the pick can get stuck on:
    • Angle the pick downward to avoid any damage.
  17. Samsung Galaxy S21 Wireless Charging Coil Replacement: 步骤 17 中的图像 1,3 Samsung Galaxy S21 Wireless Charging Coil Replacement: 步骤 17 中的图像 2,3 Samsung Galaxy S21 Wireless Charging Coil Replacement: 步骤 17 中的图像 3,3
    • Line up the opening pick's tip with your phone's flash
    • Insert the pick slowly, making sure to avoid the flash's plate.
    • The plate's resistance can feel similar to adhesive. Angle the pick downward to keep the pick from sliding into the plate.
    • Slice the adhesive to the right of the camera.
  18. Samsung Galaxy S21 Wireless Charging Coil Replacement, Remove the back cover: 步骤 18 中的图像 1,2 Samsung Galaxy S21 Wireless Charging Coil Replacement, Remove the back cover: 步骤 18 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the back cover.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone until the back cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  19. Samsung Galaxy S21 Wireless Charging Coil Replacement, Unfasten the motherboard bracket: 步骤 19 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Use a Phillips screwdriver to remove the five 4 mm-long screws securing the motherboard bracket to the frame.
    • Throughout this repair, keep track of each screw, and make sure it goes back exactly where it came from.
  20. Samsung Galaxy S21 Wireless Charging Coil Replacement, Unclip the motherboard bracket: 步骤 20 中的图像 1,2 Samsung Galaxy S21 Wireless Charging Coil Replacement, Unclip the motherboard bracket: 步骤 20 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the frame.
    • Do not completely remove the bracket yet, as it's still attached to the wireless charging coil.
  21. Samsung Galaxy S21 Wireless Charging Coil Replacement, Disconnect the battery: 步骤 21 中的图像 1,2 Samsung Galaxy S21 Wireless Charging Coil Replacement, Disconnect the battery: 步骤 21 中的图像 2,2
    • While using tweezers, or your fingers, to hold the motherboard bracket out of the way, use a spudger to pry up the battery press connector.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  22. Samsung Galaxy S21 Wireless Charging Coil Replacement, Disconnect the wireless charging coil: 步骤 22 中的图像 1,2 Samsung Galaxy S21 Wireless Charging Coil Replacement, Disconnect the wireless charging coil: 步骤 22 中的图像 2,2
    • While still holding the motherboard bracket out of the way, use a spudger to pry up and disconnect the wireless charging coil's press connector.
  23. Samsung Galaxy S21 Wireless Charging Coil Replacement, Remove the wireless charging coil: 步骤 23 中的图像 1,3 Samsung Galaxy S21 Wireless Charging Coil Replacement, Remove the wireless charging coil: 步骤 23 中的图像 2,3 Samsung Galaxy S21 Wireless Charging Coil Replacement, Remove the wireless charging coil: 步骤 23 中的图像 3,3
    • The wireless charging coil is secured to the phone with light adhesive.
    • Use your fingers to gently peel the wireless charging coil away from the phone.
    • During reassembly, refasten the motherboard bracket screws first to properly align the charging coil into place, then firmly press the rest of the coil down to adhere it.
结论
After you've completed the repair, follow this guide to test your repair.
Alex Diaz-Kokaisl
于01/16/22注册
129,330 声望
创作了600篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,085篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 67
过去 30 天: 271
总计 6,231
