当前版本的文档还未经巡查,您可以查看最新的已查核版本。
简介
请按照本指南卸下和更换 盖乐世 S10 的后置摄像头模块。该模块包括所有三个后置摄像头以及固定它们的框架。
'根据购买S10的位置而定,相机模块可能有所不同。'
在遵循本指南之前,请先检查手机和更换配件。此过程需要卸下主板。最难的部分是卸下后盖。
你所需要的
将一个SIM卡针插入SIM卡槽旁边的洞里,或是一个拉直的回形针插入SIM卡槽旁边的洞里,SIM卡槽位于手机顶部边缘的塑料天线带旁边。
稍用力按下去,把卡槽按出。
拿开SIM卡卡槽。
将手机的加热右边缘放在约0.5英寸(13毫米)厚的物体上。这使手机成为打开工具的角度。
用手指支撑手机的左边缘,这样手机就不会滑动。用坚固的压力拉动吸盘。
将打开工具的边缘按入后盖和框架之间的接缝中。
沿着接缝来回几次滑动撬棒工具。
重复之前的步骤,再次试着插入撬棒。
加热 iOpener 并将其涂抹在手机的同一边缘两分钟。
在手机背面使用一个吸盘,尽可能靠近右边缘的中心(粘合剂最窄的地方)。
用强力,稳定的力拉动吸盘,在后盖和框架之间形成间隙。
将开口三角撬片的尖端插入间隙。
如果你在撬开时遇到困难,最好的办法是向边缘施加更多热量并再次尝试上一步。
你可以尝试在接缝中涂几滴高浓度(超过90%)的异丙醇,以帮助软化粘合剂。
这个步骤还没有翻译 帮忙翻译一下
Using your fingers, grasp the motherboard by the top corners.
Swing the motherboard slightly out of its recess. Be careful not to snag any cables along the way.
Pull the motherboard towards the top edge of the phone while wiggling the board slightly. This will loosen the charging port from its socket.
Once the charging port is freed from its socket, remove the motherboard.
Align the motherboard's charging port with the bottom edge of the phone.
Gently push the motherboard against the bottom edge of the phone until the charging port is completely seated.
Lower the motherboard and press into place. Be careful not to trap any cables underneath the motherboard. The board should sit flush against the frame.
请按逆序重组设备。
请按逆序重组设备。
11等其他人完成本指南。
由衷感谢以下译者:
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
8条评论
I only wanted to know, what cameras are used in Galaxy S10/e, are they from Sony or Samsung used its own?
I’m sure I could combine info and figure it out on my own, but is there anywhere I can find instructions on only replacing the camera lens glass? I’m not the best at figuring this stuff out and getting it right. Any help is appreciated.
Hi, I had to replace the cover on my lens, and now the only one that focuses clear is .5. The rest are blurry. IF I replace this, will it fix that?
i having camera issue, camera failed . Even check with *#0*# camera still unable. Changing the camera module will solve this?
ngoh aywen - 回复
hello, if you have an authorized Samsung dealer around you they can diagnose the problem at a very affordable fee
