跳转到主内容
Samsung Galaxy Note10+ Wireless Charging Coil Replacement
你所需要的
  1. Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Heat the rear cover: 步骤 1 中的图像 1,1
    • Completely power off your phone before you begin disassembly.
    • Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Insert an opening pick: 步骤 2 中的图像 1,3 Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Insert an opening pick: 步骤 2 中的图像 2,3 Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Insert an opening pick: 步骤 2 中的图像 3,3
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • If your rear cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  3. Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Begin to slice the adhesive: 步骤 3 中的图像 1,3 Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Begin to slice the adhesive: 步骤 3 中的图像 2,3 Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Begin to slice the adhesive: 步骤 3 中的图像 3,3
    • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
    • Don't insert the opening pick more than halfway into the phone or you risk damaging internal components.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  4. Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Slice around the perimeter of the phone: 步骤 4 中的图像 1,3 Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Slice around the perimeter of the phone: 步骤 4 中的图像 2,3 Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Slice around the perimeter of the phone: 步骤 4 中的图像 3,3
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
    • The rear cover will begin to separate from the phone as you finish all sides of the phone.
  5. Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Lift off the rear cover: 步骤 5 中的图像 1,2 Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Lift off the rear cover: 步骤 5 中的图像 2,2
    • Lift the rear cover straight up to remove it.
    • Follow this guide to reinstall the rear cover and replace the adhesive.
    • Be sure to turn on your device and test your repair before installing new adhesive and resealing the device.
    • If you're using Tesa tape to reattach components, follow this guide.
  6. Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Lift up the metal cover: 步骤 6 中的图像 1,1
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
  7. Samsung Galaxy Note10+ Wireless Charging Coil Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy Note10+ Wireless Charging Coil Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy Note10+ Wireless Charging Coil Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
  8. Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Disconnect the battery: 步骤 8 中的图像 1,2 Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Disconnect the battery: 步骤 8 中的图像 2,2
    • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
  9. Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Disconnect the wireless charging coil: 步骤 9 中的图像 1,2 Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Disconnect the wireless charging coil: 步骤 9 中的图像 2,2
    • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
  10. Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Remove the wireless charging coil: 步骤 10 中的图像 1,3 Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Remove the wireless charging coil: 步骤 10 中的图像 2,3 Samsung Galaxy Note10+ Wireless Charging Coil Replacement, Remove the wireless charging coil: 步骤 10 中的图像 3,3
    • Tilt the metal shielding up so you can grip it with your fingers.
    • Peel the wireless charging coil up and away from the device.
    • The wireless charging coil is secured to the phone with some light adhesive.
    • Remove the wireless charging coil.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
7等其他人完成本指南。
Carsten Frauenheim
于03/10/20注册
155,196 声望
创作了439篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,605篇指南
1指南评论
Is there step to test see if the new charging coil working or not before closing the back cover? because once the back cover close means it's done deal.
Michael Liang - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 84
总计 7,561
