跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Note 3 Rear Facing Camera Replacement
你所需要的
    1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove the rear case: 步骤 1 中的图像 1,1
      • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: 步骤 2 中的图像 1,2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: 步骤 2 中的图像 2,2
      • Slide your fingernail or plastic opening tool along the edge of the rear case.
      • Lift the case gently from the base.
      添加评论
    1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: 步骤 3 中的图像 1,2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: 步骤 3 中的图像 2,2
      • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
      • Lift the battery out of its recess.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, S Pen: 步骤 4 中的图像 1,1
      • Place your fingernail in the groove of the stylus pen.
      • Pull the stylus pen away from the phone.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unscrew Back Chassis: 步骤 5 中的图像 1,1
      • Remove the twelve 4mm Phillips #00 screws from the back chassis.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Back Chassis: 步骤 6 中的图像 1,1
      • Insert the plastic opening tool into the Stylus Pen placement holder.
      • Lift the plastic opening tool so that the midframe separates from the base.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: 步骤 7 中的图像 1,2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: 步骤 7 中的图像 2,2
      • Remove the single screw beside headphone jack.
      添加评论
    2. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: 步骤 8 中的图像 1,2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: 步骤 8 中的图像 2,2
      在这个步骤中使用的工具:
      • Use tweezers to remove both antenna clips.
      • Use a spudger to disconnect six cable connectors.
      询问修复机器人
      添加评论
    3. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Motherboard Removal: 步骤 9 中的图像 1,1
      • Pull up on the motherboard with tweezers.
      添加评论
    1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unclipping the Camera: 步骤 10 中的图像 1,1
      • Unclip the camera connecting cable using the plastic opening tool from the motherboard
      • Remove loose camera from base
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
37等其他人完成本指南。
Brittany Gail
于09/23/14注册
8,581 声望
创作了8篇指南
团队
USF Tampa, Team 2-2, Blackwell Fall 2014 USF Tampa, Team 2-2, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S2G2
4 名成员
创作了56篇指南
3指南评论
Awesome, phone disassembly and fingernail painting at same time :) Thanks for your time to post this!
Chris G - 回复 分享
Hi
Thanks for the nice instructions
Do you know if I can use a Note 4 camera (or any better!) for my Note 3?
Are they different in connections?
Thanks
hameidfehri - 回复 分享
I shall be very thankfull for this act of kindness
Malik wajdan ali - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 47
总计 14,260
