跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Nexus Screen Replacement
你所需要的
  1. Samsung Galaxy Nexus Screen Replacement, Back of Phone: 步骤 1 中的图像 1,1
    • You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
    询问修复机器人
    添加评论
  2. Samsung Galaxy Nexus Screen Replacement, Removal of Back Cover: 步骤 2 中的图像 1,3 Samsung Galaxy Nexus Screen Replacement, Removal of Back Cover: 步骤 2 中的图像 2,3 Samsung Galaxy Nexus Screen Replacement, Removal of Back Cover: 步骤 2 中的图像 3,3
    • Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
    询问修复机器人
    添加评论
  3. Samsung Galaxy Nexus Screen Replacement, Removal of Battery: 步骤 3 中的图像 1,3 Samsung Galaxy Nexus Screen Replacement, Removal of Battery: 步骤 3 中的图像 2,3 Samsung Galaxy Nexus Screen Replacement, Removal of Battery: 步骤 3 中的图像 3,3
    • Insert your finger into the divot of the battery and pull the battery towards yourself to remove.
    • This is when a new battery will be inserted.
    询问修复机器人
    添加评论
  4. Samsung Galaxy Nexus Screen Replacement, Motherboard: 步骤 4 中的图像 1,3 Samsung Galaxy Nexus Screen Replacement, Motherboard: 步骤 4 中的图像 2,3 Samsung Galaxy Nexus Screen Replacement, Motherboard: 步骤 4 中的图像 3,3
    • Remove 4.4 mm screws using a PH # 000 as indicated on the picture.
    添加评论
  5. Samsung Galaxy Nexus Screen Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Nexus Screen Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Nexus Screen Replacement: 步骤 5 中的图像 3,3
    • After removing the screws be sure to turn the phone right side up.
    • Insert your plastic opening tool between the screen and the outer case. Move the opening tool around the phone without removing it from in between the screen and the shell of the phone.
    • Pop the screen out of the outer shell. Be cautious not to damage the control board or the screen.
    询问修复机器人
    添加评论
  6. Samsung Galaxy Nexus Screen Replacement, Removing Control Board: 步骤 6 中的图像 1,2 Samsung Galaxy Nexus Screen Replacement, Removing Control Board: 步骤 6 中的图像 2,2
    • Unscrew 4.4mm with a PH #000 marked screw.
    添加评论
  7. Samsung Galaxy Nexus Screen Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy Nexus Screen Replacement: 步骤 7 中的图像 2,2
    • With the flat head screw driver pull up the blue connector.
    添加评论
  8. Samsung Galaxy Nexus Screen Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy Nexus Screen Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy Nexus Screen Replacement: 步骤 8 中的图像 3,3
    • With you finger or prying tool pull back bottom module.
    添加评论
  9. Samsung Galaxy Nexus Screen Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy Nexus Screen Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy Nexus Screen Replacement: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove the internal battery using tweezers or your flat head screw driver.
    • There is glue at the bottom keeping battery and chassis stuck together.
    询问修复机器人
    添加评论
  10. Samsung Galaxy Nexus Screen Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Nexus Screen Replacement: 步骤 10 中的图像 2,2
    • Peel the display connector strip off the main circuit board using the tweezers.
    • Peel the USB connector strip off the main circuit board using the tweezers.
    添加评论
  11. Samsung Galaxy Nexus Screen Replacement: 步骤 11 中的图像 1,3 Samsung Galaxy Nexus Screen Replacement: 步骤 11 中的图像 2,3 Samsung Galaxy Nexus Screen Replacement: 步骤 11 中的图像 3,3
    • Remove the antenna using either your fingers or tweezers.
    询问修复机器人
    添加评论
  12. Samsung Galaxy Nexus Screen Replacement: 步骤 12 中的图像 1,3 Samsung Galaxy Nexus Screen Replacement: 步骤 12 中的图像 2,3 Samsung Galaxy Nexus Screen Replacement: 步骤 12 中的图像 3,3
    • Using tweezers, pull the top circuit board off.
    • Depending on your model, there may be ribbon cable connectors attached to the underside of the board. Be careful not to rip them out of the sockets when removing the board.
    添加评论
  13. Samsung Galaxy Nexus Screen Replacement, Screen Replacement: 步骤 13 中的图像 1,3 Samsung Galaxy Nexus Screen Replacement, Screen Replacement: 步骤 13 中的图像 2,3 Samsung Galaxy Nexus Screen Replacement, Screen Replacement: 步骤 13 中的图像 3,3
    在这个步骤中使用的工具:
    • With your tweezers remove the bottom circuit from the screen.
    询问修复机器人
    添加评论
  14. Samsung Galaxy Nexus Screen Replacement: 步骤 14 中的图像 1,2 Samsung Galaxy Nexus Screen Replacement: 步骤 14 中的图像 2,2
    • Now you are left with just the screen of the phone.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
stewilli
于09/22/14注册
1,500 声望
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 62
总计 5,532
