跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Mega Front Facing Camera Replacement
你所需要的
    1. Samsung Galaxy Mega Front Facing Camera Replacement, Battery: 步骤 1 中的图像 1,3 Samsung Galaxy Mega Front Facing Camera Replacement, Battery: 步骤 1 中的图像 2,3 Samsung Galaxy Mega Front Facing Camera Replacement, Battery: 步骤 1 中的图像 3,3
      • Before starting, ensure device is completely turned off.
      • On the back of phone, locate the slot on the top left corner.
      • Insert plastic opening tool or fingernail and pull up on the back plate.
      • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
      添加评论
    2. Samsung Galaxy Mega Front Facing Camera Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Mega Front Facing Camera Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Mega Front Facing Camera Replacement: 步骤 2 中的图像 3,3
      • Insert fingernail into the slot on bottom of battery and gently pull up.
      • Remove the battery.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Mega Front Facing Camera Replacement, Midframe: 步骤 3 中的图像 1,3 Samsung Galaxy Mega Front Facing Camera Replacement, Midframe: 步骤 3 中的图像 2,3 Samsung Galaxy Mega Front Facing Camera Replacement, Midframe: 步骤 3 中的图像 3,3
      • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
      • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
      • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
      添加评论
    2. Samsung Galaxy Mega Front Facing Camera Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Mega Front Facing Camera Replacement: 步骤 4 中的图像 2,2
      • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
      • The device should easily come apart after the plastic opening tool is slid around the entire device.
      • During reassembly, ensure volume and power buttons align properly.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Mega Front Facing Camera Replacement, Front Facing Camera: 步骤 5 中的图像 1,1
      • Remove the one 2.55 mm Phillips #000 screw from top left of motherboard assembly.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Mega Front Facing Camera Replacement: 步骤 6 中的图像 1,1
      • Remove metal cover with plastic opening tool.
      询问修复机器人
      添加评论
    3. Samsung Galaxy Mega Front Facing Camera Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy Mega Front Facing Camera Replacement: 步骤 7 中的图像 2,2
      • Lift the motherboard connector and remove the camera assembly from phone.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Max Rathman
于02/04/16注册
915 声望
创作了4篇指南
团队
USF Tampa, Team 17-2, Blackwell Winter 2016 USF Tampa, Team 17-2, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S17G2
4 名成员
创作了72篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 41
总计 1,186
