简介
This guide will walk you through the process of replacing a not working back camera in a Samsung Galaxy J3V.
你所需要的
Place your thumb on the top left corner and pry the tab open and lift off the back cover.
在这个步骤中使用的工具:Tweezers$4.99
Remove connector tab with spudger then carefully remove headphone jack with tweezers.
After removing the motherboard, locate and flip tab holding the rear camera's connector.
Carefully use the tweezer to remove the connector and the camera.
另外一个人完成了本指南。
