跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Express 3 Screen Replacement
你所需要的
    1. Samsung Galaxy Express 3 Screen Replacement, Battery: 步骤 1 中的图像 1,2 Samsung Galaxy Express 3 Screen Replacement, Battery: 步骤 1 中的图像 2,2
      • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Express 3 Screen Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Express 3 Screen Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Express 3 Screen Replacement: 步骤 2 中的图像 3,3
      • Once the cover is removed, locate the battery that reads "SAMSUNG."
      • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
      • Do not use a metal tool, as it can cause injury.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Express 3 Screen Replacement, Screen: 步骤 3 中的图像 1,2 Samsung Galaxy Express 3 Screen Replacement, Screen: 步骤 3 中的图像 2,2
      • Use a Plastic Prying Tool (such as a spudger) to pop out piece shown.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Express 3 Screen Replacement: 步骤 4 中的图像 1,1
      • Detach the screen connector.
      询问修复机器人
      添加评论
    3. Samsung Galaxy Express 3 Screen Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Express 3 Screen Replacement: 步骤 5 中的图像 2,2
      • Use a blow dryer or heating pad to heat up the screen.
      • Do not skip this step, as it may result in a broken screen and/or LCD.
      • This step loosens the glue holding the screen in place.
      添加评论
    4. Samsung Galaxy Express 3 Screen Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy Express 3 Screen Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy Express 3 Screen Replacement: 步骤 6 中的图像 3,3
      • Use a Thin Plastic Tool (such as a guitar pick) or Plastic Prying Tool (such as a spudger) to lift out the glass digitizer and LCD screen around the edges.
      • Do this slowly and carefully, as both parts can crack very easily.
      • Ensure your tool is plastic, as a metal tool can damage the screen easily.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
2指南评论
My friend set on his phone the screen is broken. The phone will come on but the screen will not light up.
Rudolph Mc Alister - 回复 分享
Same! For TWO phones now… have you had any luck on any suggestions or figuring anything out???
Faith Dockery - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 42
总计 4,225
