跳转到主内容
加入维修社区 - 创建账户
Samsung Eternity Digitizer and Screen Replacement
你所需要的
      • Remove the back battery cover.
      询问修复机器人
      添加评论
    1. Samsung Eternity Digitizer and Screen Replacement: 步骤 2 中的图像 1,1
      • Using a nylon spudger, remove the phone's battery.
      询问修复机器人
      添加评论
    2. Samsung Eternity Digitizer and Screen Replacement: 步骤 3 中的图像 1,1
      • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    3. Samsung Eternity Digitizer and Screen Replacement: 步骤 4 中的图像 1,2 Samsung Eternity Digitizer and Screen Replacement: 步骤 4 中的图像 2,2
      • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
      询问修复机器人
      添加评论
    1. Samsung Eternity Digitizer and Screen Replacement, Motherboard: 步骤 5 中的图像 1,1
      • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
      • Pull the antenna plug out of its socket.
      询问修复机器人
      添加评论
    2. Samsung Eternity Digitizer and Screen Replacement: 步骤 6 中的图像 1,3 Samsung Eternity Digitizer and Screen Replacement: 步骤 6 中的图像 2,3 Samsung Eternity Digitizer and Screen Replacement: 步骤 6 中的图像 3,3
      • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
      询问修复机器人
      添加评论
    3. Samsung Eternity Digitizer and Screen Replacement: 步骤 7 中的图像 1,1
      • Pop the red hinged-release lever away from its ribbon. Then pull it out.
      询问修复机器人
      添加评论
    4. Samsung Eternity Digitizer and Screen Replacement: 步骤 8 中的图像 1,1
      • Peel the button sensor on the side of the motherboard off of the case.
      询问修复机器人
      添加评论
    5. Samsung Eternity Digitizer and Screen Replacement: 步骤 9 中的图像 1,3 Samsung Eternity Digitizer and Screen Replacement: 步骤 9 中的图像 2,3 Samsung Eternity Digitizer and Screen Replacement: 步骤 9 中的图像 3,3
      • Slightly pull up one side of the motherboard.
      • Pull the button/microphone plug out of its socket.
      • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
      询问修复机器人
      添加评论
    6. Samsung Eternity Digitizer and Screen Replacement: 步骤 10 中的图像 1,1
      • You have successfully removed the motherboard from the phone.
      询问修复机器人
      添加评论
    1. Samsung Eternity Digitizer and Screen Replacement, Digitizer and Screen: 步骤 11 中的图像 1,1
      • Flip the phone over so you are looking at the front screen of the phone.
      询问修复机器人
      添加评论
    2. Samsung Eternity Digitizer and Screen Replacement: 步骤 12 中的图像 1,3 Samsung Eternity Digitizer and Screen Replacement: 步骤 12 中的图像 2,3 Samsung Eternity Digitizer and Screen Replacement: 步骤 12 中的图像 3,3
      • Use a small tool to pry the digitizer and screen (together) from the frame of the phone.
      • This may take some time and careful work because it is glued down to the frame.
      • Be careful when you pull the lower part of this piece away from the phone frame because there is a ribbon attached to the digitizer that you don't want to break. There is also a ribbon on the side of the screen to be aware of.
      询问修复机器人
      添加评论
    3. Samsung Eternity Digitizer and Screen Replacement: 步骤 13 中的图像 1,3 Samsung Eternity Digitizer and Screen Replacement: 步骤 13 中的图像 2,3 Samsung Eternity Digitizer and Screen Replacement: 步骤 13 中的图像 3,3
      • Next, carefully pull the digitizer away from the screen.
      • At this point you can replace either the screen or the digitizer.
      • Cleaning the screen with a glass cleaning cloth before reassembling will remove any smudges or fingerprints from disassembling the device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
团队
Cal Poly, Team 15-11, Regan Spring 2011 Cal Poly, Team 15-11, Regan Spring 2011 的会员
CPSU-REGAN-S11S15G11
5 名成员
创作了35篇指南
3指南评论
You did not mention how to glue the digitizer to LCD. That is a very important step.
cashyapan - 回复 分享
Do these steps also work for the Samsung Eternity 2?
Brian Coukis The 90's Kid! - 回复 分享
Está mierda no sale
Luz esther Martinez Pérez - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 40
总计 7,346
