跳转到主内容
Samsung Brightside Speaker Module Replacement
你所需要的
  1. Samsung Brightside Speaker Module Replacement, Speaker Module: 步骤 1 中的图像 1,3 Samsung Brightside Speaker Module Replacement, Speaker Module: 步骤 1 中的图像 2,3 Samsung Brightside Speaker Module Replacement, Speaker Module: 步骤 1 中的图像 3,3
    • Here is the Samsung SCH-U380 Brightside
    • Turn it over to gain access to the battery.
    • Remove the backcover by simply pulling it off the phone from the top down
  2. Samsung Brightside Speaker Module Replacement: 步骤 2 中的图像 1,3 Samsung Brightside Speaker Module Replacement: 步骤 2 中的图像 2,3 Samsung Brightside Speaker Module Replacement: 步骤 2 中的图像 3,3
    • Remove the battery
    • Remove the six Phillips screws from the back frame
    • All six screws are identical M1.5X3
  3. Samsung Brightside Speaker Module Replacement: 步骤 3 中的图像 1,3 Samsung Brightside Speaker Module Replacement: 步骤 3 中的图像 2,3 Samsung Brightside Speaker Module Replacement: 步骤 3 中的图像 3,3
    • Use a plastic opening tool or similar tool to separate the top from the bottom frame. Applying slight pressure in a downwards direction will disengage the plastic clips
    • Continue to slide the tool along the slot until you feel the plastic locks disengage
    • Once all locks have released, the bottom frame can simply be removed.
  4. Samsung Brightside Speaker Module Replacement: 步骤 4 中的图像 1,3 Samsung Brightside Speaker Module Replacement: 步骤 4 中的图像 2,3 Samsung Brightside Speaker Module Replacement: 步骤 4 中的图像 3,3
    • Remove the two Phillips screws from the EMI shield.
    • Both screws are identical M1.5X2
    • Remove the EMI shield
  5. Samsung Brightside Speaker Module Replacement: 步骤 5 中的图像 1,3 Samsung Brightside Speaker Module Replacement: 步骤 5 中的图像 2,3 Samsung Brightside Speaker Module Replacement: 步骤 5 中的图像 3,3
    • Detach the LCD connector.
    • Remove the logic board
    • This is the speaker module. In the center is the camera, but it is not part of the module.
  6. Samsung Brightside Speaker Module Replacement: 步骤 6 中的图像 1,3 Samsung Brightside Speaker Module Replacement: 步骤 6 中的图像 2,3 Samsung Brightside Speaker Module Replacement: 步骤 6 中的图像 3,3
    • turn the logic board over. The speaker module is held in place
    • by one Phillips screw
    • and two clips
    • Remove the Phillips screw.
    • It is a M1X2 Phillips screw
    • Next disengage one of the clips by simply applying some sideways pressure with your fingernail. This will loosen the module.
  7. Samsung Brightside Speaker Module Replacement: 步骤 7 中的图像 1,2 Samsung Brightside Speaker Module Replacement: 步骤 7 中的图像 2,2
    • Turn the logic board around. With the speaker module loose, simply lift it off the board.
    • Speaker module removed.
    • Camera
    • and audio jack
    • are not part of this module and will remain on the board.
结论
oldturkey03
于09/29/10注册
739,782 声望
创作了116篇指南
团队
Global Fixers Global Fixers 的会员
Community
24 名成员
创作了369篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 936
