跳转到主内容
加入维修社区 - 创建账户
本篇指南是分解流程而非维修指南。 如果您要维修您的SONY WH-1000XM3,应参考我们的维修指南。
    1. SONY WH-1000XM3, 取下海绵耳罩: 步骤 1 中的图像 1,1
      • 使用撬棍,从边缘翘起耳罩,建议从左侧或者右侧
      • 左右耳方式一致
      询问修复机器人
      添加评论
    2. SONY WH-1000XM3, 拧下螺丝并打开: 步骤 2 中的图像 1,3 SONY WH-1000XM3, 拧下螺丝并打开: 步骤 2 中的图像 2,3 SONY WH-1000XM3, 拧下螺丝并打开: 步骤 2 中的图像 3,3
      • 拧下所有螺丝,上方有 5 颗短螺丝,底部有 4 颗长螺丝。
      • 小心地打开后盖,你可以看到 NFC 天线连接在主板上。
      • 看起来是贴纸下方的布线纠缠在一起导致了这个问题。我尝试稍微整理了一下,电源按钮就恢复正常了。
      添加评论
由衷感谢以下译者:
en zh
100%
jiangyaoyaode正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
leonw87
于11/30/19注册
85 声望
撰写一个指南
7指南评论
Thank you very much leonw87. My headphones are working again thanks to your instructions. I changed the battery first, unfortunately without success.
After I sorted the cables on the board a bit, I stuck a tape over the connection points so that they are better fixed.
Great job from you.
JayJay - 回复 分享
THANK YOU
my headphones fell cause I''m an idiot, used to turn on after many tries so I gave this a shot and worked perfectly
el Foresto - 回复 分享
I dont have enough words to explain how appreciate your help. I have been months with my hearphones left out in a box thinkin they were broken or whatever. You literally saved my life rn bro. Thank you so much <3
zouhair naoumi - 回复 分享
is it possible to replace the Bluetooth module with that of the newer version so I can get multi point connection
Darth Darth - 回复 分享
Had the same issue after mine fell off my head at the gym. Followed your guide and they're working again good as new. Thank you for the guide
Grant Vrban Brown - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 22
过去 7 天: 142
过去 30 天: 568
总计 15,648
