跳转到主内容
加入维修社区 - 创建账户
SKYTEX SP1020 Battery Replacement
你所需要的
    1. SKYTEX SP1020 Battery Replacement, Rear Case: 步骤 1 中的图像 1,2 SKYTEX SP1020 Battery Replacement, Rear Case: 步骤 1 中的图像 2,2
      • Prior to any repairs make sure that you are familiar with the device as well as the location of its buttons and ports.
      • Turn off device prior to continuing to further steps.
      询问修复机器人
      添加评论
    2. SKYTEX SP1020 Battery Replacement: 步骤 2 中的图像 1,3 SKYTEX SP1020 Battery Replacement: 步骤 2 中的图像 2,3 SKYTEX SP1020 Battery Replacement: 步骤 2 中的图像 3,3
      • Set the tablet back panel facing down, with the SKYTEX logo facing you. You will find that this step will start from the right side of the device.
      • Insert the plastic opening tool between the bottom seam of the back panel and the micro SD port. The tool's edge should point toward the rear panel to prevent any scratching or damage.
      • Follow up with the plastic opening tool, releasing the clips as you go all the way around the device.
      询问修复机器人
      添加评论
    3. SKYTEX SP1020 Battery Replacement: 步骤 3 中的图像 1,1
      • The clips will be released in the order specified as the spudger tool is moved along the seam around the device.
      询问修复机器人
      添加评论
    4. SKYTEX SP1020 Battery Replacement: 步骤 4 中的图像 1,1
      • Use a plastic opening tool to pry the speakers out of the rear case.
      • The rear case will now be free from the rest of the device.
      询问修复机器人
      添加评论
    1. SKYTEX SP1020 Battery Replacement, Battery: 步骤 5 中的图像 1,1
      • Locate the battery.
      询问修复机器人
      添加评论
    2. SKYTEX SP1020 Battery Replacement: 步骤 6 中的图像 1,1
      • Use a soldering iron and desoldering braid to desolder the red and black motherboard battery connections.
      询问修复机器人
      添加评论
    3. SKYTEX SP1020 Battery Replacement: 步骤 7 中的图像 1,1
      • Gently lift the battery up and out of the device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
UMass Dartmouth, Team 1-6, Miles Spring 2015 UMass Dartmouth, Team 1-6, Miles Spring 2015 的会员
UMASSD-MILES-S15S1G6
4 名成员
创作了8篇指南
1指南评论
Great Instructions! where did you get the battery for the Skytex ?
joe_capozzi - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 31
总计 1,075
