跳转到主内容
加入维修社区 - 创建账户
SG 552-1 Commando Spring Replacement
你所需要的
  1. SG 552-1 Commando Spring Replacement, Gearbox: 步骤 1 中的图像 1,2 SG 552-1 Commando Spring Replacement, Gearbox: 步骤 1 中的图像 2,2
    • Using a flathead screwdriver, remove the pin holding the hand guard in place.
    • To remove this, turn the pin clockwise and push it through at the same time.
    • Remove the hand guard.
    询问修复机器人
    添加评论
  2. SG 552-1 Commando Spring Replacement: 步骤 2 中的图像 1,2 SG 552-1 Commando Spring Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun.
    • There should be four total.
    询问修复机器人
    添加评论
  3. SG 552-1 Commando Spring Replacement: 步骤 3 中的图像 1,2 SG 552-1 Commando Spring Replacement: 步骤 3 中的图像 2,2
    • Turn the gun over so that you are facing the bottom of the gun.
    • Using a Phillips #1 screwdriver, remove the following screws:
    • Remove the 8mm screw that is located directly underneath the cocking lever.
    • Remove the 8mm screw located beside the screw you just removed.
    询问修复机器人
    添加评论
  4. SG 552-1 Commando Spring Replacement: 步骤 4 中的图像 1,2 SG 552-1 Commando Spring Replacement: 步骤 4 中的图像 2,2
    • Carefully tug on the tip of the gun and pull the barrel and its cover out.
    询问修复机器人
    添加评论
  5. SG 552-1 Commando Spring Replacement: 步骤 5 中的图像 1,3 SG 552-1 Commando Spring Replacement: 步骤 5 中的图像 2,3 SG 552-1 Commando Spring Replacement: 步骤 5 中的图像 3,3
    • Locate the hand grip.
    • Using a Phillips #0 screwdriver, remove the two 6mm screws at the bottom of the hand grip.
    • Slide the cover off.
    询问修复机器人
    添加评论
  6. SG 552-1 Commando Spring Replacement: 步骤 6 中的图像 1,2 SG 552-1 Commando Spring Replacement: 步骤 6 中的图像 2,2
    • Pull the motor out of the hand grip.
    • Using a Phillips #1 screwdriver, remove the two 5mm screws inside of the hand grip.
    询问修复机器人
    添加评论
  7. SG 552-1 Commando Spring Replacement: 步骤 7 中的图像 1,2 SG 552-1 Commando Spring Replacement: 步骤 7 中的图像 2,2
    • Locate the pin holding the folding stock in place.
    • Using an allen wrench or something small, carefully push the pin out.
    询问修复机器人
    添加评论
  8. SG 552-1 Commando Spring Replacement: 步骤 8 中的图像 1,2 SG 552-1 Commando Spring Replacement: 步骤 8 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the 20mm screw behind the folding stock and above the gearbox.
    • Remove the cover that was held on by the screw.
    询问修复机器人
    添加评论
  9. SG 552-1 Commando Spring Replacement: 步骤 9 中的图像 1,3 SG 552-1 Commando Spring Replacement: 步骤 9 中的图像 2,3 SG 552-1 Commando Spring Replacement: 步骤 9 中的图像 3,3
    • Using a flathead screwdriver, remove the two 5mm screws beside the safety switch on both sides of the gun.
    • Slide off the piece that was held on by those screws.
    询问修复机器人
    添加评论
  10. SG 552-1 Commando Spring Replacement: 步骤 10 中的图像 1,2 SG 552-1 Commando Spring Replacement: 步骤 10 中的图像 2,2
    • Using a small allen wrench, carefully unscrew the screws holding the safety switch in place on both sides of the gun.
    • The screws do not have to be taken out all the way, just slightly loosen them until you are able to pull the switch off.
    询问修复机器人
    添加评论
  11. SG 552-1 Commando Spring Replacement: 步骤 11 中的图像 1,2 SG 552-1 Commando Spring Replacement: 步骤 11 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove the two 6mm screws that were underneath the safety switch on both sides of the gun.
    • Carefully remove the pieces that were held on by the screws.
    询问修复机器人
    添加评论
  12. SG 552-1 Commando Spring Replacement: 步骤 12 中的图像 1,3 SG 552-1 Commando Spring Replacement: 步骤 12 中的图像 2,3 SG 552-1 Commando Spring Replacement: 步骤 12 中的图像 3,3
    • Pull apart the cover when pulling the gearbox out.
    • Pull the gearbox out.
    • The gears will fall out when taking the gearbox out. Careful not to lose them.
    询问修复机器人
    添加评论
  13. SG 552-1 Commando Spring Replacement, Spring: 步骤 13 中的图像 1,2 SG 552-1 Commando Spring Replacement, Spring: 步骤 13 中的图像 2,2
    • Remove these four 15mm screws.
    • Remove this single 8mm screw.
    • Using a Phillips #0 screwdriver, remove the following screws:
    • Remove this single 3mm screw.
    • Remove this single 14mm screw.
    • Detach the pieces unscrewed from the gearbox.
    询问修复机器人
    添加评论
  14. SG 552-1 Commando Spring Replacement: 步骤 14 中的图像 1,2 SG 552-1 Commando Spring Replacement: 步骤 14 中的图像 2,2
    • Remove the piece covering the trigger.
    • Remove the safety piece.
    • Using a Phillips #1 screwdriver, remove the 18mm screw beside the trigger.
    询问修复机器人
    添加评论
  15. SG 552-1 Commando Spring Replacement: 步骤 15 中的图像 1,1
    • Remove the metal piece.
    • Removing this piece will permanently damage the metal piece.
    询问修复机器人
    添加评论
  16. SG 552-1 Commando Spring Replacement: 步骤 16 中的图像 1,3 SG 552-1 Commando Spring Replacement: 步骤 16 中的图像 2,3 SG 552-1 Commando Spring Replacement: 步骤 16 中的图像 3,3
    • Remove the cover and pull out the spring.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Anika Morris
于10/05/12注册
1 声望
创作了4篇指南
团队
Cal Poly, Team 18-41, Regan Fall 2012 Cal Poly, Team 18-41, Regan Fall 2012 的会员
CPSU-REGAN-F12S18G41
6 名成员
创作了6篇指南
1指南评论
When i read step 15 it seems impossible to up/downgrade spring without damaging the gun permanently??
Marco den Hartog - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 36
总计 2,336
