跳转到主内容
加入维修社区 - 创建账户
SEGA Genesis Flashback Controller Buttons Replacement
你所需要的
  1. SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: 步骤 1 中的图像 1,3 SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: 步骤 1 中的图像 2,3 SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: 步骤 1 中的图像 3,3
    • Hold the controller with the bottom plate facing up, and gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside.
    • Remove the screws on the back of the controller with the Phillips #000 screwdriver.
    • Be sure to separate the two plates with the bottom facing up, to keep the buttons from falling out.
    询问修复机器人
    添加评论
  2. SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: 步骤 2 中的图像 1,2 SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: 步骤 2 中的图像 2,2
    • CAUTION: Pull gently on the rubber membranes to avoid tearing .
    • Use two fingers to remove each rubber membrane that rests on top of the buttons.
    询问修复机器人
    添加评论
  3. SEGA Genesis Flashback Controller Buttons Replacement: 步骤 3 中的图像 1,1
    • Pop the button out from the front side of the controller.
    • Pull the button out from the backside using the other hand.
    • All removable buttons can only be placed in their respective holes due to unique groove patterns on the buttons. Keep in mind where each button belongs to make re-assembly easier.
    • All buttons can be removed except for the D-Pad.
    询问修复机器人
    添加评论
  4. SEGA Genesis Flashback Controller Buttons Replacement: 步骤 4 中的图像 1,1
    • Repeat Step 3 for the remaining buttons.
    • The button should pop out seamlessly and placed to the side.
    • Repeat the prior steps in order to remove all the buttons. Set them aside in an order you will remember to where they belong.
    询问修复机器人
    添加评论
结论
After completing step 4 you will need to re-assemble your controller. Do this by starting from step 2 and work backwards. Take your e-waste to an R2 or e-Stewards certified recycler.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Viet Nguyen
于04/17/18注册
220 声望
创作了2篇指南
团队
Cal Poly, Team S24-G12, Maness Spring 2018 Cal Poly, Team S24-G12, Maness Spring 2018 的会员
CPSU-MANESS-S18S24G12
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 46
总计 2,241
