跳转到主内容
加入维修社区 - 创建账户
Ryobi P202 Trigger Assembly Replacement
你所需要的
    1. Ryobi P202 Trigger Assembly Replacement, Battery: 步骤 1 中的图像 1,3 Ryobi P202 Trigger Assembly Replacement, Battery: 步骤 1 中的图像 2,3 Ryobi P202 Trigger Assembly Replacement, Battery: 步骤 1 中的图像 3,3
      • The battery can shock you. Only touch plastic, non-conductive components.
      • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
      询问修复机器人
      添加评论
    1. Ryobi P202 Trigger Assembly Replacement, Right Side Case: 步骤 2 中的图像 1,2 Ryobi P202 Trigger Assembly Replacement, Right Side Case: 步骤 2 中的图像 2,2
      • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
      询问修复机器人
      添加评论
    2. Ryobi P202 Trigger Assembly Replacement: 步骤 3 中的图像 1,2 Ryobi P202 Trigger Assembly Replacement: 步骤 3 中的图像 2,2
      • Gently lift the casing from the drill body.
      • Take the casing completely off the drill body to gain access to the interior of the drill.
      • The Ryobi P202 casing has Part #: 200690001
      询问修复机器人
      添加评论
    1. Ryobi P202 Trigger Assembly Replacement, Battery Contacts: 步骤 4 中的图像 1,2 Ryobi P202 Trigger Assembly Replacement, Battery Contacts: 步骤 4 中的图像 2,2
      • Grip the battery clip and pull straight up to remove the metal battery contacts.
      • You can now clean the metal battery contacts with isopropyl alcohol.
      询问修复机器人
      添加评论
    1. Ryobi P202 Trigger Assembly Replacement, Trigger Assembly: 步骤 5 中的图像 1,2 Ryobi P202 Trigger Assembly Replacement, Trigger Assembly: 步骤 5 中的图像 2,2
      • Holding the direction select switch in place, grip both sides of the trigger assembly and lift it up and towards the base of the drill.
      询问修复机器人
      添加评论
    2. Ryobi P202 Trigger Assembly Replacement: 步骤 6 中的图像 1,2 Ryobi P202 Trigger Assembly Replacement: 步骤 6 中的图像 2,2
      • To separate the trigger assembly from the motor, use a soldering iron to melt the solder and pull gently on the red and black wires from the trigger.
      • Heating the solder may melt the plastic packaging. Prior experience with soldering is required.
      • The trigger assembly is Part #: 270001392
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. You will need solder to reattach the wires to the trigger assembly.
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team 17-6, Forte Spring 2015 Cal Poly, Team 17-6, Forte Spring 2015 的会员
CPSU-FORTE-S15S17G6
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 58
总计 5,754
