跳转到主内容
加入维修社区 - 创建账户
Ryobi CSB125 Protective Shell Replacement
你所需要的
    1. Ryobi CSB125 Protective Shell Replacement, Protective Shell: 步骤 1 中的图像 1,1
      • Place the saw on a flat surface with the blade facing up.
      • Make sure that the saw is unplugged from any power source.
      询问修复机器人
      添加评论
    2. Ryobi CSB125 Protective Shell Replacement: 步骤 2 中的图像 1,1
      • Remove the bumper by using the T20 Torx screwdriver to loosen the M5 x 20mm screw.
      询问修复机器人
      添加评论
    3. Ryobi CSB125 Protective Shell Replacement: 步骤 3 中的图像 1,2 Ryobi CSB125 Protective Shell Replacement: 步骤 3 中的图像 2,2
      • Use the 7”/32 allen key to loosen the 5/16-18 x 9/16 in. blade screw.
      询问修复机器人
      添加评论
    4. Ryobi CSB125 Protective Shell Replacement: 步骤 4 中的图像 1,1
      • Remove the 5/16-18 x 9/16 in. blade screw, spring washer, the outer blade washer, the blade, and the inner blade washer.
      询问修复机器人
      添加评论
    5. Ryobi CSB125 Protective Shell Replacement: 步骤 5 中的图像 1,3 Ryobi CSB125 Protective Shell Replacement: 步骤 5 中的图像 2,3 Ryobi CSB125 Protective Shell Replacement: 步骤 5 中的图像 3,3
      • Use the Phillips #2 screwdriver to remove the four M4x16mm screws shown.
      • You will need to rotate the protective shell around in order to access them.
      询问修复机器人
      添加评论
    6. Ryobi CSB125 Protective Shell Replacement: 步骤 6 中的图像 1,1
      • Remove the lower blade guard support assembly from the rest of the saw.
      • Remove the protective shell.
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
Curtis Melo
于10/31/19注册
1,093 声望
创作了5篇指南
团队
UMass Dartmouth, Team S2-G1, Barthe Fall 2019 UMass Dartmouth, Team S2-G1, Barthe Fall 2019 的会员
UMASSD-BARTHE-F19S2G1
3 名成员
创作了10篇指南
4指南评论
Instructions fail at step #5. Bottom-left screw is under the plastic blade guard which blocks removal of the screw. Blade guard covers the screw no matter how it’s positioned.
Michael Bluejay - 回复 分享
If you wiggle the plastic you can remove
I was able to remove… be patient it does work
Adrian Isbister - 回复 分享
Instructions also fail at step #6. I have no idea how to remove the plastic blade guard from the axle so I can transfer it to the new (replacement) blade guard.
I also was struggling… … but if you look closely there is a thin metal ring around the center plastic ring that the spindle runs through… this has a split in it…. I used a small flat Precision screwdriver (type used to tighten reading glasses,etc)and was able to pry at the split and remove the thin metal ring.
Once removed this frees the plastic guard and it drops right out.
Just reverse to reassemble.
This works… just be patient
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 32
总计 2,841
