跳转到主内容
加入维修社区 - 创建账户
Rowenta Focus Material Setting Knob Replacement
你所需要的
  1. Rowenta Focus Material Setting Knob Replacement, Power Assembly: 步骤 1 中的图像 1,2 Rowenta Focus Material Setting Knob Replacement, Power Assembly: 步骤 1 中的图像 2,2
    • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
    • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
    询问修复机器人
    添加评论
  2. Rowenta Focus Material Setting Knob Replacement: 步骤 2 中的图像 1,3 Rowenta Focus Material Setting Knob Replacement: 步骤 2 中的图像 2,3 Rowenta Focus Material Setting Knob Replacement: 步骤 2 中的图像 3,3
    • Pry the back cover of the iron off using a metal spudger.
    • Remove the back cover, exposing the wiring in the iron.
    询问修复机器人
    添加评论
  3. Rowenta Focus Material Setting Knob Replacement: 步骤 3 中的图像 1,2 Rowenta Focus Material Setting Knob Replacement: 步骤 3 中的图像 2,2
    • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
    • Leave the other cords attached to the main cord.
    询问修复机器人
    添加评论
  4. Rowenta Focus Material Setting Knob Replacement: 步骤 4 中的图像 1,2 Rowenta Focus Material Setting Knob Replacement: 步骤 4 中的图像 2,2
    • Pull out the motherboard inside handle of iron.
    • Keep it attached to main power cord and other components.
    添加评论
  5. Rowenta Focus Material Setting Knob Replacement: 步骤 5 中的图像 1,3 Rowenta Focus Material Setting Knob Replacement: 步骤 5 中的图像 2,3 Rowenta Focus Material Setting Knob Replacement: 步骤 5 中的图像 3,3
    • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
    添加评论
  6. Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: 步骤 6 中的图像 1,3 Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: 步骤 6 中的图像 2,3 Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: 步骤 6 中的图像 3,3
    • Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
    • Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
    • Lift out the piece.
    询问修复机器人
    添加评论
  7. Rowenta Focus Material Setting Knob Replacement: 步骤 7 中的图像 1,3 Rowenta Focus Material Setting Knob Replacement: 步骤 7 中的图像 2,3 Rowenta Focus Material Setting Knob Replacement: 步骤 7 中的图像 3,3
    • Replace with an identical part by inserting it into the space.
    询问修复机器人
    添加评论
  8. Rowenta Focus Material Setting Knob Replacement, Heating Element/Soleplate: 步骤 8 中的图像 1,2 Rowenta Focus Material Setting Knob Replacement, Heating Element/Soleplate: 步骤 8 中的图像 2,2
    • Using the T20 screwdriver, remove the 20 mm screw that was under the steam and spray button.
    询问修复机器人
    添加评论
  9. Rowenta Focus Material Setting Knob Replacement: 步骤 9 中的图像 1,2 Rowenta Focus Material Setting Knob Replacement: 步骤 9 中的图像 2,2
    • Unhook the clips on the top of the metal piece.
    • Using the metal spudger, remove the metal piece on the tip of the iron.
    询问修复机器人
    添加评论
  10. Rowenta Focus Material Setting Knob Replacement: 步骤 10 中的图像 1,2 Rowenta Focus Material Setting Knob Replacement: 步骤 10 中的图像 2,2
    • Using the T20 screwdriver, remove the 20 mm screw that was under the metal piece on the tip of the iron.
    询问修复机器人
    添加评论
  11. Rowenta Focus Material Setting Knob Replacement: 步骤 11 中的图像 1,3 Rowenta Focus Material Setting Knob Replacement: 步骤 11 中的图像 2,3 Rowenta Focus Material Setting Knob Replacement: 步骤 11 中的图像 3,3
    • Using the T20 screwdriver, remove the two 20 mm screws on either side of the back of the iron.
    询问修复机器人
    添加评论
  12. Rowenta Focus Material Setting Knob Replacement: 步骤 12 中的图像 1,3 Rowenta Focus Material Setting Knob Replacement: 步骤 12 中的图像 2,3 Rowenta Focus Material Setting Knob Replacement: 步骤 12 中的图像 3,3
    • Lift the iron up using the handle to completely detach the soleplate.
    询问修复机器人
    添加评论
  13. Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: 步骤 13 中的图像 1,3 Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: 步骤 13 中的图像 2,3 Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: 步骤 13 中的图像 3,3
    • Using the T20 screwdriver, remove both of the 20mm screws on the underside of the iron.
    询问修复机器人
    添加评论
  14. Rowenta Focus Material Setting Knob Replacement: 步骤 14 中的图像 1,2 Rowenta Focus Material Setting Knob Replacement: 步骤 14 中的图像 2,2
    • Turn the iron over and pull the knob off.
    • Be careful not to tip the iron after removing the knob; there are small springs in the white piece underneath the knob.
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
1指南评论
Nice pics, came apart easily with this guide. Just need a note on the small ball bearing which I assume goes somewhere on the steam valve?
Step - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 72
总计 2,335
